Noise and judder when steering on hard left lock
Sheewa
Wed May 08 2019, 12:34pm
Member No: #3244
Good Afternoon everyone
When I put the steering wheel into a fairly hard left turn there is "squealing " noise from the engine compartment and a judder through the steering wheel.
It only seems to happen when the car is cold i.e. first thing in the morning.
Been told I need to top up the LDS fluid. The tensioner had seized but the mechanic freed it up and it stopped for a couple of days.
Can anyone confirm that or have alternate suggestions please?
Wed May 08 2019, 05:19pm
By all means check the LDS fluid level first but I doubt it will be that.
The power steering pump is working it's hardest when the LDS is cold and at full lock. The squealing sounds like a slipping aux drive belt which suggests the tensioner repair was a temporary fix.
I would say you need a new tensioner and belt.
Best of luck
Sheewa
Thu May 09 2019, 01:15pm
Member No: #3244
Thank you MG Mike. Will get it booked in for a once over.
