Lag acelerator |
rmonf24 |
Member No: #3300
Well that my citroen c6 since always and noticed that when you step on the accelerator does not respond immediately, someone knows if Lexia can be solved? Thank you. |
Hello, most likely an issue with your Swirl pipes and or actuator. Link to PDF repair info below by Vaho. - Click Here - |
Is the Swirl system the same on 3.0 Hdi ? When I have a "lag" I suspect the gearbox learning system and think it becomes better after a little fresh driving. But I may be wrong and should check this system ? The lazyness is only sometimes and mostly in town traffic. Accelleration on tho open road is good. | ||
ul9601 |
Member No: #1975
I've driven three 2.7 HDi, they are more or less the same, unfortunately. I've done swirl valve jobs and made no difference. |
Tjensen wrote ... No, Tjensen; no swirl valve system on the 3. Well, no visible system, at least...Is the Swirl system the same on 3.0 Hdi ? When I have a "lag" I suspect the gearbox learning system and think it becomes better after a little fresh driving. But I may be wrong and should check this system ? The lazyness is only sometimes and mostly in town traffic. Accelleration on tho open road is good. |
Don't forget it's a 2.7 and prone to turbo lag from a standing start. | ||
e3steve, I think I spotted swirl valves. Lower mounted and piped differently. Have a look lower down the front of the engine for the front one. Let me know what you think. Best regards, Phil C. |
