c6 3.0 fap smoke from engine
joaoproenca
Wed Dec 19 2018, 07:16pm
Member No: #1510
Dear All,
My C6 had a intermittent smoke leak from engine compartment. Smoke is from engine exhaust due to smell and colour and is noticeable when running due smell and with car stooped if no wind it can be seen.
Conditions are car engine warmed up after auto Ban driving.
When car is stooped and engine idling you listen to a click and after the engine start to leak smoke from right side. I forced already EGR on and off and is not from EGR.
Any Ideas ? as this car have also an A by-pass device for the exhaust gas recycling (EGR) exchanger, with a flap controlled by a pneumatic actuator.
Warm Regards to All
Joao
Wed Dec 19 2018, 07:54pm
I had a similar problem. It was diesel fumes from a leaking connection on the high-pressure side.
 joaoproenca (19 December 2018)
FraserG
Wed Dec 19 2018, 08:30pm
Member No: #2011
I had a smoking engine last month. Not the same as yours I don't think as it was accompanied by the engine chuffing like a train. It turned out to be a copper washer on one of the injectors perforating.
1 User said Thank You to FraserG for this Post :
joaoproenca
Wed Dec 19 2018, 10:17pm
Member No: #1510
What do you mean with high pressure side ?
Thu Dec 20 2018, 11:05pm
It was close to the injectors, between injectors and the HP pump
Sat Dec 22 2018, 11:25am
Tjensen wrote ...
I also had a leak a few years back when working extensively on the (2.7) it was from the Egr connection on the hard to reach rear EGR valve. The bolt/gasket hadn't sealed well enough and exhaust fumes were seen in the engine bay.
Dave
joaoproenca
Wed Apr 22 2020, 10:13am
Member No: #1510
The fail was at exhaust system collector back of engine symptoms are:
-white smoke come from engine bay when doing the regeneration due post injection;
-smell of burned diesel when idling and stoped as part of waste get inside the car
The leak can only be seen with car lift and when pumping the throttle with engine running
Joao
2 User said Thank You to joaoproenca for this Post :
 C6Dave (22 April 2020) , cruiserphil (27 April 2020)
