RT5 display: HR or LR ?
m3mpower
Tue Aug 30 2016, 08:51pm
Member No: #662
Hi
You'll have to configure the resolution output on your RT4 to accept the high resolution screen.
PIT
Tue Aug 30 2016, 09:03pm
Member No: #2671
That's for sure
PIT
Tue Aug 30 2016, 09:10pm
Member No: #2671
As I see, the displays also have some firmware. Does this matter when changing it?
m3mpower
Tue Aug 30 2016, 11:07pm
Member No: #662
No it doesnt matter
AndreSMCXXMC6
Wed Aug 31 2016, 07:01pm
Member No: #615
I do know the 407 version fits with a minor modification in the C6 housing.
I am not sure about the C5 III version.
AndreSMCXXMC6
Wed Aug 31 2016, 07:05pm
Member No: #615
You have to change the settings with MIRASCRIPT for the Hi-RES font and the display as the 407 display is upside down.
PIT
Tue Oct 11 2016, 01:21pm
Member No: #2671
I see that it is easier to fins RNEG or RNEG2 displays. As i see on the pictures they also use the same type of cable to connect to the main unit. I'm wondering if they are compatible also with RT4/5...
drumvlado
Fri Sep 21 2018, 03:28pm
Member No: #3669
Hello Andre, is this a photo of the HR display? The part numbers and the numbers on the back are completely irrelevant and this makes it difficult to trace it second hand.
Thanks,
Vladimir
AndreSMCXXMC6 wrote ...
All C6 have a Low-Res display. You can replace it with a Hi-Res display
from eg a late 2009 Peugeot 407 Hi-Res diaplay (you have to cut the "ears"
off to make them fit)
Fri Sep 21 2018, 03:53pm
drumvlado wrote ...
Thanks,
Vladimir
Hi drunvlado, The 96-beginning number ends with 580 i believe if its hi-res screen and it also says MMF-DEVHR.
AndreSMCXXMC6
Sat Sep 22 2018, 12:20pm
Member No: #615
Yes that is a High Res display. You have to cut off the "ears"to adapt to the C6 housing. You need MIRASCRIPT to change the setting to Hi-Res and reverse the screen.
drumvlado
Mon Sep 24 2018, 02:28pm
Member No: #3669
Thanks! Just got one off eBay.
Tue Sep 25 2018, 08:29am
drumvlado wrote ...
I still haven't started my retro fit of a new screen and RT5 to my 2.7 C6.
I'm actually nervous I think of screwing with the nice all in one piece dash.
I think I'll need some more dash photos and a bit more reading before I'll be ok to open the dash up. If anyone has anymore detailed photos of where clips and screws are placed that would be great.
m3mpower
Tue Sep 25 2018, 01:12pm
Member No: #662
See the photos attached for more details
Wed Sep 26 2018, 10:47pm
m3mpower wrote ...
Thanks for the photos. I noticed the plastic clips have metal clips on the ends(sort of spring loaded) hadn't noticed before.
Jakub
Wed May 05 2021, 12:10am
Member No: #4120
Hello;
Someone before mentioned that C4 Picasso display should work. Have anyone tried it? They are much easier to get than late 407 display. I've noticed that all displays for C4GP are made by Continental, so, I guess, came from cars equipped with RNEG.
I've found elsewhere that RNEG and RT4/5 displays are using the same interface and are compatibile. Is that true?
Go to page   <<
