max. RPM about 3000. |
meliskay72 |
Member No: #1645
My c6 2.7HDi, Lignage, '58 plate (and manufacture), 80,782 miles, has recently come back from my local cit. garage at driffield after a quite ext(p)ensive set of repairs etc. including new timing belt, new alternator/water pump belt, new front discs and pads, new front hubs/hub carriers, track rod ends, ABS sensors, complete new plastic thermostat housing, front suspension hydraulic supply pipe replaced, all necessary fluids, interim service, replaced C.V boot, front n.s; wheel alignment, mot etc. etc. Now I am finding a "hesitancy" in gear changes (Automatic), a very lethargic rate of progress, and an unwillingness and inability for the engine to achieve 3000 RPM. I would appreciate any guidance or pointers as to where the problem may lie before embarking on another costly contribution to the garages' retirement pot. n.b no messages on the dashboard for a clue. regards, meliskay. |
Limiting at 3,000 rpm is usually a sign that the car has gone into 'limp' mode to protect the engine because of a fault. The repairs at your CIT Dealer (Broach Hill?) should be covered under repair warranty (12 month on parts and 6 months on labour IIRC) so give them a call. |
arconell3 |
Member No: #922
Since your timing belt was changed, the very first thing to check is whether the valve timing is correct!! It wouldn't be the first time that a timing belt change resulted in a ruined engine. In both cases I know of, the garage doing the change (Cit dealer workshops!) didn't use the required Cit tools to do the job... They simply didn't have them available... Regards, Robert |
Pracli |
Member No: #3537
I had the same problem, and the root cause was weak fuel pressure I changed the belt for the high pressure pump Seems to be OK for now Try to read error codes, may be there is P0193 and/or P1164 |
meliskay72 |
Member No: #1645
I spoke to Neill @ Broach Hill about the problem now extant with GF58OUG since its various works, about a week ago. They were (as always), extremely busy, but I arranged to take the car in yesterday, Wednesday. I was advised that they would try to "get on it" yesterday afternoon or this morning, and would phone me with any findings. So far nothing heard, although I have a courtesy car from them (18.40 hrs.) There will be more to follow. | ||
meliskay72 |
Member No: #1645
Had a call from Neill @ Broach Hill yester evening (16/7 ), 18.16hrs. He advises all previous works are o.k. but fault code readout, (the only one!), 0243; turbo pressure regulator electrovalve errors on turbo 1, which is the rear one. He says the only soln. is a new turbo, as its associated wiring etc. back to the ECU checks out ok (per a cit. advisory bulletin). This is a £1700+ labour+vat hit, and I am now beginning to question whether or not this is a price too steep, given the value of the car. Any serious thoughts anyone please? | ||
arconell3 |
Member No: #922
It seems somewhat unlikely that P0243 is indeed the only fault code. Simply because if indeed the regulator valve on Turbo 1 is at fault, turbo 2 is still OK. Which means a discrepancy in mass air flow exists between MAF 1 and MAF 2, triggering the corresponding fault code as well.... Having said that, my advice is: go to your dealer, tell them to reset the fault, take the car for a long spin and see what happens. Go back to the workshop and let them make another readout, make sure you get a copy. Am I being too suspicious? Maybe I am, but it doesn't cost you anything to give it a try. Regards, Robert |
CP07 has a similar fault which I believe is down to the rear EGR value. Has your garage used a lexia or a generic code reader? |
MGmike wrote ... Has your garage used a lexia or a generic code reader? Broach Hill are a CIT Main Dealer with a very good reputation. @meliskay, If you Google the Turbo part number 0375K£ you can find a part number for a Garrett 723341-0012 (Citroen list them as 'Honywell' but same company) - Click Here - Googling the Garrett number finds them on Amazon at £396.45 each or eBay at £225! - Click Here - Me I would buy the eBay one and get it fitted by a non franchise dealer with far lower labour costs.... |
meliskay72 |
Member No: #1645
Latest update. 1) The garage @ Broach Hill are I believe, cit. main dealers. Their diagnostics are up to date and cit/peug specific. 2) There was another set of readings along with P0243, these being:- engine ECU, P010F air flow meter signals. P010E flow meter signal 2 (front) 3) I am now advised that the price of £1700 includes fitting and vat, so I was wrong there. It does push this years spend over the £4k mark though, so still some heavy thinking imminent. 4) I am picking the car up tomorrow a.m, and will obtain copies of the various then. 5) The mechanic took the car up the road today, after clearing all fault codes. It behaved ok for about 5 miles, then lost its "poke" again. On return to the garage the P0243 was back. regards to all. meliskay72 |
meliskay72 |
Member No: #1645
To Dave-Retired. Just my luck, yours of today arrived whilst I was typing my "update". Your notes re the alternatives to a cit.gen part are very interesting and seriously cheaper. I will have to see if I can locate a competent installer, as I suspect it is quite tricky at the back of the engine; also, is part registration in the ECU involved? Many many thanks. meliskay72 |
Hattershaun |
Has your car ever had either of the EGR valves changed? I was a passenger in a 2.7hdi C6 recently that wouldn't rev over 3000rpm & had restricted/virtually no acceleration. Turned out both EGR valves needed replacing. Once replaced normal performance resumed. I'd say every 2.7HDi will need EGR valves changing sometime, usually between 50-100,000 miles. |
travlician |
Member No: #350
The turbo electovalve is a know issue to fail. Citroen does not provide the elctrovalve itself and does state it needs to be changed as a complete turbo unit. I managed to get the electrovale off, solder in new wires to the stepper motor inside and has been good so far. There is a batch of these electrovalves (2006-2007) with this issue. | ||
If you look at the fault code error sheet you can see what the car does when that code appears but you haven't said that the engine management light comes on the dashboard display? If you want to see what's involved changing the rear turbo on a 2.7 HDi download the guide: - Click Here - You can also show it to a local garage to see if they are happy to change it for you, or if you want to try and do it yourself..... |
arconell3 |
Member No: #922
Hi Dave, the document on the EDC is from the 3.0 HDI with Bosch ECU, the 2.7 has a Siemens ECU. However, and as far as I know, it works the same on the 2.7. Now, before buying any new turbochargers, check the wiring on the variable control, i.e. get the plug off, check for dirty contacts/greasy contacts, clean and put back on. Reset all faults again. I know, sometimes these control units can fail, but it doesn't happen all that often. And what's more: I am (again) a bit surprised that the fault reoccurred while driving. As Dave's document above will tell you, in line 4, the fault can only be recorded when switching off the engine (dormant mode) and flashed (MIL) when the ignition is turned back on. Which is consistent with the behavior I have seen on a 2.7 with the same fault code. So, did the mechanic switch off the engine after 5 miles and restarted or did the car go into limb mode, engine running while driving? Regards, Robert |
