Suspension not working properly |
M2dis |
Member No: #3475
Where the f are maxi fuses under the bonnet? Pump is not doing anything anymore and I decided to check if the fuse is blown or not but couldn't figure out how do access them. | ||
They are under the main engine bay fuse box. have a look in the tech section for more details. You'll need to disconnect the plugs from the fuse box, unbolt the main feed and lift out (after disconnecting the battery before starting of course!). Chances are the plastic retaining clips will break but they're optional extras |
M2dis |
Member No: #3475
It's solved finally. I asked around from Estonian enthusiasts and got a pretty solid answer that pump is to blame and another C6 one will fit 100%. Bought the one from 2.7 diesel from near me for 200 EUR and my local service swapped it. Everything is working as should again. Also asked the old pump back and will see if I can find anyone who could bring it back to life so I'd have some backup. |
