How to remove the radio |
Ciaran
![]() Member No: #3087
Lads, Maybe a stupid question, but how do you remove the radio / head unit? I have all the usual removal pins etc, but there is only one hole at each side of the unit. There is a plastic strip along the top of the radio, under the vents, which looks like it may pry out with trim tools, but it seems fastened quite firmly and I don't want to break something. Am I missing something really obvious? (probably) ![]() I've spent quite a while searching on here and Google, but can't find any direct reference to it. Answers on a postcard, much appreciated! Ciarán |
Cisco
![]() ![]() Member No: #1429
Hi Ciaran, You need a long Torx T10 driver in each of the two holes to loosen the captive fixing screws then the head unit pulls out. Deploy the cup holders to get a grip on the unit. Double check the Torx size as it's a while since I removed the unit. ATB Frank |
Yep. T10... | ||
Ciaran
Thanks guys, appreciate it. I was poking the solitary hole with the removal pins and wondering was there a second hole hidden behind the trim strip or something - D'oh! Cheers again. Ciarán |
