screen on c6 navdrive blank in places |
whiskdabs |
Member No: #2977
Can any one help me my screen on my c6 2.7 auto 2009 has 2 blank strips but rest of screen still showing. as i can not read the time on right side of screen or in middle. do i need another screen or system if any one can help please let me know | ||
m3mpower |
Member No: #662
whiskdabs wrote ... Can any one help me my screen on my c6 2.7 auto 2009 has 2 blank strips but rest of screen still showing. as i can not read the time on right side of screen or in middle. do i need another screen or system if any one can help please let me know Hi What i would do is change the LVDS cable, that connects the RT4 ( i presume it's RT4 if you say 2009 ) then if it's the same, you should change the display |
whiskdabs |
Member No: #2977
Hi thank you for them 2 options regarding LVDS cable on my RT4 screen. Could you please tell me how to take the unit out and could i replace it through your help.I have tried to download a manual to see how to do this but unfort this i can not do as certain soft ware needed on my computer.I would be willing to bring car to your selfs if this would help me. |
There's a hole each side of the radio fascia. Insert a (slender) Torx T10 driver and undo the screws; the unit then just slides out. | ||
m3mpower |
Member No: #662
whiskdabs wrote ... Hi thank you for them 2 options regarding LVDS cable on my RT4 screen. Could you please tell me how to take the unit out and could i replace it through your help.I have tried to download a manual to see how to do this but unfort this i can not do as certain soft ware needed on my computer.I would be willing to bring car to your selfs if this would help me. Hi You will need to remove the headunit as described by e3steve in the previous post. You also need to remove the display fascia. see the photos attached. |
whiskdabs |
Member No: #2977
HI all a big thank-you for coming back and explaining what i have to do then could you please tell me then do i send the cable and unit to Magneti for repair or do they do a a recondition one.I do very much appreciate all of your help. Also is the car off the road while i wait for new unit until to arrive as this is my my car for work as use it all the time i love the car that much. |
m3mpower |
Member No: #662
What you need to do is order a new cable from Citroen, the part number is 6593 19. Then replace the old cable with this new cable and test the system, if the display works OK, you throw away the old cable and refit everything as it was. If the display still doesn't work as it should, then you'll need a screen replacement. You don't need to send anything to Magneti. |
m3mpower wrote ... What you need to do is order a new cable from Citroen, the part number is 6593 19. Then replace the old cable with this new cable and test the system, if the display works OK, you throw away the old cable and refit everything as it was. If the display still doesn't work as it should, then you'll need a screen replacement. You don't need to send anything to Magneti. Hi M3mpower, How much would it cost roughly to convert the RT3 system to RT4? |
m3mpower |
Member No: #662
Hi This depends of what accessories you will need, also whether your C6 has amplifier or not... Send me by PM your car's chassis number and indicate if you need full kit. |
whiskdabs |
Member No: #2977
HI All i do thank every one who has helped me in sorting out my problem as my car is i have checked on date and yes it was first date of registration 01-09-2009 stating on v5c 2720c but i do not have lounge pack. I will order cable 6593 19 from Citroen and as all of you have helped will connect and let you know outcome. I do thank every one as the car is fantastic also can any one tell me when cam belt should be changed Car has done now 110.000 |
whiskdabs wrote ... I do thank every one as the car is fantastic also can any one tell me when cam belt should be changed Car has done now 110.000 Err on the side of caution and use the 'Arduous Conditions' ( - Click Here - ) schedule and timing belt changes come at 112,500 mile or 10 years whichever is sooner. Citroen 'Fixed Price Repairs' - Click Here - will get it done for £295 and you will get a guarentee on the parts and labour |
jamescarruthers |
Member No: #1548
Dave-Retired wrote ... whiskdabs wrote ... I do thank every one as the car is fantastic also can any one tell me when cam belt should be changed Car has done now 110.000 Err on the side of caution and use the 'Arduous Conditions' ( - Click Here - ) schedule and timing belt changes come at 112,500 mile or 10 years whichever is sooner. Citroen 'Fixed Price Repairs' - Click Here - will get it done for £295 and you will get a guarentee on the parts and labour Unfortunately both my local dealers (Marshall of Cambridge and Duxford) refused to honour this deal for the C6. Marshall's were rude about it, Duxford were appologetic. How on earth can a car coming up for its first cambelt change (based on time) be considered too old for the deal to be valid. Not much annoys me like unfairness, but that is what this is. Good luck if you do get yours done at your dealership and please share the name of them if they honour their deals. |
whiskdabs |
Member No: #2977
HI all just to let you know I am waiting for a lead as waiting from Citroen cost £13.95 also to have belt fitted by Citroen cost £782.95 including vat. This is with out water pump.So at present, i will check around as they said it will take 7 hours to do the job. So do anyone knows in Suffolk or Norfolk in the UK who is cheaper or am I going the wrong way. |
whiskdabs wrote ... So do anyone knows in Suffolk or Norfolk in the UK who is cheaper or am I going the wrong way. Dan at Wolsey House Motors in Diss is worth a phone call. |
Dave-Retired wrote ... whiskdabs wrote ... So do anyone knows in Suffolk or Norfolk in the UK who is cheaper or am I going the wrong way. Dan at Wolsey House Motors in Diss is worth a phone call. If he has the time, Dave! Very busy guy... |
