Battery spec |
PercyPorcelain
![]() ![]() Joined: Jan 19 2015 Member No: #2027
What is the official battery spec for our cars? Just received a new Lucas (L100, I think it was) and while it turns the engine well enough, it's somewhat shorter than the (probably original) Citroen battery and needed to be secured forwards for sharp braking, also is rated 640ma instead of the 950ma one I took out... | ||
![]() ![]() Member No: #614
Good morning Percy, I think you observed the situation perfectly, the replacement battery you have is not the right size needed to sustain the C6. It needs the biggest strongest battery you can fit really. Because the C6 has a lot of small electric motors and a good example is the C6 windows going up and down repeatedly all day long, a small battery would be drained fairly quickly even a good one. Also how is your alternator performing? That's the other part of the act! It's a good idea to see if it's performing well and giving a correct charge back to the battery. Dave |
PercyPorcelain wrote ... Oh dear, Percy; you've been 'done'!What is the official battery spec for our cars? Just received a new Lucas (L100, I think it was) and while it turns the engine well enough, it's somewhat shorter than the (probably original) Citroen battery and needed to be secured forwards for sharp braking, also is rated 640ma instead of the 950ma one I took out... 95Ah / 800CCA minimum. Varta 'Silver' H3: 100Ah / 830CCA. Barden UK, with 5-yr warranty... |
Hi Percy, you have fallen victim to incorrect information held by most of the battery suppliers: we discovered this and documented the same back in 2012 if you check out forum posts. The correct battery will just fit into the space allocated. The only exception to this is if you elected to go for an AGM battery: then you would be on your own in terms of specification but in theory, this would give you a better battery, better able to withstand significant levels of discharge but at a much higher price. (approximately 2.5 times more expensive!!!!!) For a long life with a car that is not used a lot, I would go for an Odyssey brand of AGM (very low self discharge, excellent starting, and can happily be discharged down to say 70% of capacity without massively impacting cycle life) regards |
Too low CCA should be avoided, slow starting revs will wear on the starter bearings, and they are a weak point, at least in the 2,7. 800CCA or more is right. The 950 CCA in the original is a very high value, not easy to get. The "original spare part" is priced relatively low and is the right one. | ||
robingc33
![]() ![]() Member No: #2303
I recently replaced mine with a Silver Varta Type 019 H3 100Ah 830CCA from "batterymegauk" on ebay (currently £108.50 with free delivery). It turned up overnight, well packed and I'm very pleased with it. It's a perfect fit and has bought new life into the car, starting in particular ![]() |
Here's the first post on the battery replacement subject. I ordered the wrong battery back in 2012. It went in to the C4 and got the proper one. - Click Here - | ||
PercyPorcelain
Thanks all... remember my car is only a 2.2 (C-Crosser engine) so perhaps I'll be alright with the lower ampage. It was only 53 quid and is a Lucas... ask me again in 12 months (assuming I get through the winter!) | ||
Citroen specified the same battery for all C6 and all engines according to their parts website 'Citroen Service'. L5 - 950A and 95Ah. Most main dealers in the UK have a fixed price offer to supply & fit a battery, my local dealer's cost is £110, which I think is good value as you have to dismantle most of the internal boot trim to fit a battery. Remember, every time a C6 door is unlocked with the remote control, the suspension motor runs to self level the car and all the ECUs wake up. Open a door, the window glass drops a bit, then goes back up when the door is closed. When I bought my car at 3 years old, the first thing I did was fit a new battery, for my peace of mind, as the previous owner had used the car infrequently and for short trips in town. |
PercyPorcelain
Correct, everyone, the 640Ah battery was a disaster and is now going back. Ended up immobilised after a week or two. Pretty shocking that ebay allows vendors to blatantly misdescribe car batteries like this ("All C6 diesels from 2005"). Anyway the good news is I got a 100Ah type 019 with a 4-year warranty for under £70 which fits perfectly (though ironically, it was not specified for C6) | ||
