Dropping immediately after switching engine off? Normal. |
jamescarruthers |
Member No: #1548
Is it normal that the car drops at the front, immediately upon switching the engine off? This is before I get out the car, so it isn't correcting it's height. I thought that there would be a reserve of pressure provided by an accumulator sphere like in the XM and BX's I've had. The C6, I understand much less! Can anyone confirm if this is standard behaviour or not, please? |
James, Depends on how far it drops. Is it an inch or two or fully flat? Best regards, Phil C. |
jamescarruthers |
Member No: #1548
Not sure, will try to investigate further somehow. It's hard to tell from in the car, and if I get out, surely that will influence the test as the height corrector will compensate for me getting out. I can definitely feel it and see it when I turn off the engine. | ||
Yep. Mine does, and so does Colin's. | ||
FraserG |
Member No: #2011
Mine does this too. My previous CX's, XM, C5, BX's, DS and GSA didn't. Cheers Fraser |
jamescarruthers |
Member No: #1548
Phew! Good to know. Thanks everyone. Touch wood, after my initial mega-spend on the car everything is working and I am hammering up & down the M11 every day in luxury without problem. So far, a good, reliable car that I love! |
keithc |
Member No: #2584
Mine drops a few inches when I turn the ignition off. And then when I get out and close the car it rises back up again. And when I come back to the car and open it, it drops a few inches again. Been doing that since I bought it. I presume its to help us get in/out of the car! | ||
Jas16 |
Member No: #2994
yep mine does that too, but stays dropped until i get in and start the ignition at which it pops back up. | ||
My C5 (facelift) Hydractive II / III (?) would sit at a traffic light and to a little dance at the front end, from time to time! I'd be happily minding my own business when, suddenly, it would drop -- and I mean drop, not lower, an inch (25.4mm) -- for a few seconds; then, without any prompting, up it would pop again... | ||
