Fuel Flap Fail
ul9601
Sat Dec 31 2016, 05:17am
Member No: #1975
Went to fill the tank but realised the fuel flap wouldn't open. I could hear the solenoid trying to open it but still nothing. With someone else pushing the fuel flap open switch, I carefully levered the flap and it popped right open. It turns out a small black spring (bent to 135 degree) fell out from its slot behind the solenoid latch. The spring clipped back in, it works fine now.
2 User said Thank You to ul9601 for this Post :
 321dave (31 Dec : 22:40) , cruiserphil (01 Jan : 12:21)
onthecut
Mon Jan 02 2017, 03:18pm
Member No: #2793
That could leave you in a bit of a pickle if you were low on fuel. Not clear from your description -- is the small spring part of the flap assembly or the solenoid ?
As a matter of interest, is there a manual release lever for the fuel flap somewhere, in the evnt of solenoid failure ?
Mike.
ul9601
Tue Jan 03 2017, 12:02am
Member No: #1975
onthecut wrote ...
I'll take a photo - it just sits on the rubber boot thingy which surrounds the fuel filler neck.
onthecut wrote ...
Mike.
I was wondering this myself and looked through the owners' handbook but didn't find anything. I recall CX handbook had an emergency release procedure.
ul9601
Tue Jan 03 2017, 12:18am
Member No: #1975
 cruiserphil (05 Jan : 15:52) , nouveaucitroenist (11 Jan : 17:46)
onthecut
Tue Jan 03 2017, 10:32am
Member No: #2793
That looks like a case of no expense spent rather than no expense spared !
Mike.
