Problem to start on petrol engine (no 12V on injectors) BSI ? |
pablob |
Member No: #1290
Hi all, I hope you can let me some hints on this It is a C6 2006 Petrol Engine (V6 24V). I was was parked for 4 months (not used) and after that, it never start again. Problem: I dont have 12v on injectors. Diagnose: I´ve Spark during cranking (remove a coil an tested) I´ve fuel on the rail (fuel pump is working) I have "pulse" on injectors (I have tested it) so ECU is working. All fuse are OK Battery is OK and charged. However I dont have 12v on injectors (it has 3V) Lexia only found issues on inyectors but we suspect that this is because they are not receiving 12V. Question: Do you know who is the responsible to provide 12v on Inyectors? Do you have any wire diagram for Petrol Engines ? Many thanks ! |
