RT 4/5 system starting to fail |
Symptoms: -4 hours perfect functioning an a long trip -then darker screen and controls sluggish or not working. Even Audio OFF/ON not working OK -Died (black screen) -Tried to restart by itself and showing the Chevrons, then black again and new attempt. many times, and a high-pitched weak beeping noice -Stopped engine, had a lunch, same symptoms when starting -After a while: constant Chevrons -After 1-2 hours: restarted succesfully by itself and... perfect after that If this is a once-a-year thing it is OK, but if it something to worry about, I should worry and do something. Never happened like this before, but 2 small incidents with the systems 1 and 3 years ago Ideas ? |
Possible Hard Disk about to Fail? or simply hard disk needs Defrag? Regards G |
