Where is Indicator Flasher? |
Kwiatek |
Member No: #2462
Hello! Anyone know where is flasher/interrupter direction (i use translate)? I want replace on electronic flasher for LED bulbs. Best regards |
I doubt that there is one. At least, not one like 'the old days' of normal, pre-CAN-bus electrical systems. Nowadays most lighting switching is handled within the BSI. Try firing up the hazard warning lights (with the ignition off) and listen for a relay clicking within the electronics' enclosure, under the bonnet and to the left of the engine bay. The tick-tock noise you hear within the car's interior is generated via a piezo-electric sounder; the same one that beeps the seatbelt, lights-on & key-in warnings. |
You can buy flasher specific LEDs, and just change the bulb | ||
Hi all, IMHO fitting a LED bulb to an indicator is solving a problem that doesn't exist. What's wrong with the OEM filiament bulb? Note, >5 years of C6 ownership, only 2 indicator bulb changes and they were pre-emptive anyhow because I had the headlights on the bench. Regards G |
