Protective under panel. |
Huutch |
Member No: #2112
I know it's a long shot, but is there anywhere where I can buy the plastic protector under panel underneath the car, as part of mine has come off and the rest of it looks unrepairable. Thanks. | ||
Yep a Citroen Dealer or Eurocarcare as Mick can order most things and sell on with a discount. Used ones will more than likely also be damaged. |
Cisco |
Member No: #1429
Here you go - Click Here - These fit well but you need to buy the soundproofing separately and stick it on. The fixing pins and clips are also available on the bay. Frank |
Cisco wrote ... Here you go - Click Here - These fit well but you need to buy the soundproofing separately and stick it on. The fixing pins and clips are also available on the bay. Frank I priced the full citroen part this week at €170.97 that's including of course the sound proofing and heat shield. Part no: 7013EL I'm also replacing the engine sump and gasket while I'm at it. Sump is badly corroded because of the cracked undertray. Kind regards 321dave |
I bought mine from Nero Bart, on eBay, for about £39, delivered. Fits perfectly. | ||
Huutch |
Member No: #2112
Thanks for the responses. Will this fit? - Click Here - | ||
Different part number, you need 7013 EL not 7013 SI - not sure just what the differences are though. | ||
Yup. that's the one I have; they've dropped in price! Fits perfectly, although none except the Citroën OEM has the soundproofing. |
