Re-Coding a Key
Stew U
Fri May 22 2015, 11:28am
Member No: #698
Hi All,
Just replaced the battery in my keyfob and the key now appears to be de-coded. Checked and replaced the battery to make sure it wasn't this. Looking on the internet a C3 forum said that to re-code the keys, I should turn the ignition to the 2nd position and hold the lock button down for 10 sec, then wait 1 min inside the car and then the key should work.
Does anyone know if this works for a C6? I don't want to stop my backup key working if this doesn't work.
Thanks,
Stew
(apologies if this has been asked before - I couldn't see a thread on it)
1 User said Thank You to Stew U for this Post :
 321dave (15 July 2019)
Fri May 22 2015, 03:23pm
The question is if the blade is cut to fit the ignition, will these steps work To reprogram the key to the car:
- Key in ignition (ignition off)
- Turn key to ignition on, and press and hold locking button for about 5 secs.
- Release button on fob
- Turn ignition off
- Wait about 10-15secs and fob programming should be complete.
3 User said Thank You to C6Dave for this Post :
 e3steve (25 May 2015) , 321dave (15 July 2019) , ceeso (16 July 2019)
Sat May 23 2015, 08:28pm
Yes, this procedure worked for me in the past.
2 User said Thank You to cruiserphil for this Post :
Mon Jul 15 2019, 10:19am
4 years later and it still works this way if your key fob battery has died and been replaced.
Key in ignition, turn on, wait 5 seconds, turn off but leave key in place for 15 seconds before removing.
Worked for me today.
4 User said Thank You to C6Dave for this Post :
 cruiserphil (15 July 2019) , 321dave (15 July 2019) , e3steve (15 July 2019) , ceeso (16 July 2019)
ceeso
Tue Jul 16 2019, 06:47pm
Member No: #1788
Sound advice that works effectively. Having the key fob re-programmed is another thing off the list. Now to establish why there's so much water in the spare wheel well in the boot... c'est la vie Citroen
1 User said Thank You to ceeso for this Post :
 321dave (16 July 2019)
Wed Jul 17 2019, 08:13am
ceeso wrote ...
Have a look at the rear light clusters, dirt can build up at the top end where the rubber section covers the gutter section, the car I bought recently had a blocked gutter, moisture in the light unit and water in the boot.
Removed the light cluster and cleaned everything before fitting a replacement unit and the boot now stays dry. Doesn't take long as there are only 2 wing nuts holding each one in place.
 cruiserphil (07 October 2019) , Garfield (25 February 2020)
