Re-Coding a Key |
Stew U |
Member No: #698
Hi All, Just replaced the battery in my keyfob and the key now appears to be de-coded. Checked and replaced the battery to make sure it wasn't this. Looking on the internet a C3 forum said that to re-code the keys, I should turn the ignition to the 2nd position and hold the lock button down for 10 sec, then wait 1 min inside the car and then the key should work. Does anyone know if this works for a C6? I don't want to stop my backup key working if this doesn't work. Thanks, Stew (apologies if this has been asked before - I couldn't see a thread on it) |
The question is if the blade is cut to fit the ignition, will these steps work To reprogram the key to the car: - Key in ignition (ignition off) - Turn key to ignition on, and press and hold locking button for about 5 secs. - Release button on fob - Turn ignition off - Wait about 10-15secs and fob programming should be complete. |
Yes, this procedure worked for me in the past. Best regards, Phil C. |
4 years later and it still works this way if your key fob battery has died and been replaced. Key in ignition, turn on, wait 5 seconds, turn off but leave key in place for 15 seconds before removing. Worked for me today. |
ceeso |
Member No: #1788
Sound advice that works effectively. Having the key fob re-programmed is another thing off the list. Now to establish why there's so much water in the spare wheel well in the boot... c'est la vie Citroen | ||
ceeso wrote ... Sound advice that works effectively. Having the key fob re-programmed is another thing off the list. Now to establish why there's so much water in the spare wheel well in the boot... c'est la vie Citroen Have a look at the rear light clusters, dirt can build up at the top end where the rubber section covers the gutter section, the car I bought recently had a blocked gutter, moisture in the light unit and water in the boot. Removed the light cluster and cleaned everything before fitting a replacement unit and the boot now stays dry. Doesn't take long as there are only 2 wing nuts holding each one in place. |
