Sidelights to LED's |
Open the bonnet and you will see a triangular panel with 3 round clips, the centre of the lifts up (but doesn't come out) lift the centre of the clips to release the lock and then remove all three clips![]() once you done this, you remove the rubber seal and move the triangular panel out of the way, once you done this you can see a circular rubber bung ![]() This should just pull off but may need a little help to break the seal. with that out of the way you can see a white lever, this needs twisting towards the back of the car slighty to unlock it from the mount. ![]() you can then extract the bulb and change it for the LED ![]() Refitting is just the reverse. the bulbs I used were these: - Click Here - PLESASE NOTE: They will not fit the number plate holders as the bulbs are to long, I'm currently searching for some to do that |
magicands
Great photos, thanks for the guide as well. I used these number plate LED's and they work just great. - Click Here - |
Leeant
![]() ![]() Joined: Nov 11 2015 Member No: #2397
I have just done this. Took me 20 minutes maximum and that was in the dark. Excellent guide. |
Norman
![]() ![]() ![]() Member No: #364
I Used the same number plate lights on mine they are very bright indeed | ||
Chris Burmajster
![]() ![]() ![]() Member No: #81
Sorry to be the one here, but can I state that I can't find the "rubber seal and move the trangle part out of the way". Is this the rubber multi plug shown in the second picture? | ||
No Chris, picture 1, the rubber seal around the engine bay. | ||
Chris Burmajster
Thank you! | ||
