Good garages in England
Harvey
Tue Feb 10 2015, 01:52pm
We recently took our C6 to a Citreon dealership for new brake discs and pads and it came back with ABS faults, parking brake fault and ESP faults (all new problems). We decided not to take the car back to the garage and will steer clear of it in the future. Can anybody recommend a good honest garage in the Beds/Herts/Bucks/Cambs area? Further afield would be considered too. Many thanks
Tue Feb 10 2015, 01:58pm
Hi Harvey, you might soon add in Sat Nav faults to your list.
The ABS, ESP, Parking brake faults are probably all caused by the same issue (a faulty rear ABS sensor or cable or connector).
In fairness to the dealer, this could have happened with any "good" garage. It just depends on whether there was an underlying fault.
How did the dealer explain himnself and what was the offered explanation/solution?
Tue Feb 10 2015, 02:19pm
Harvey wrote ...
We have a 'Service Review' section where you can search via post code - Click Here - but probably the best for C6's in your area would be BL Autos - Click Here -
Tue Feb 10 2015, 10:20pm
I can recommend BLAutos, they work on all my cars, for the last 15+ years.
Many other C6 owners have found them knowledgeable, skilled and good value.
They are all long standing Citroen enthusiasts too.
Wed Feb 11 2015, 02:09pm
Member No: #82
For bucks, go to Forge in Cookham. Very good. Actually it might be in Berks, just.
userpco
Wed Feb 11 2015, 02:56pm
Member No: #622
I second the recommendation of Forge in Cookham. Have used them for a year now, fixed ABS/Parking brake warnings (rear sensor) and have subsequently had a service, all at £60/hr
alanr7
Sun Feb 22 2015, 06:22pm
Member No: #304
Hi had exaclly the same fault on a 2006 2.7 c6,after two weeks in a citroen garage they traced it to the main abs block this was replaced and the car is working fine no faults not a cheap job hope this helps cheers alan
drummond
Sun Feb 22 2015, 09:49pm
I, also, go to Forge in Cookham (yes, it's Berks), they've had my C6 in there for servicing , and minor fettling, for years and also I've had various faults corrected on the roadster- which no longer breaks down......
Mon Feb 23 2015, 09:26am
drummond wrote ...
Really Tim, like a Rolls Royce, Tractions 'may fail to proceed' without warning
grandadmark
Tue Sep 27 2016, 02:32pm
Member No: #508
I have a problem. My garage (Frontlines in Chesterfield) of many years is closing.
Can anyone recommend a good independent garages within 10 miles or so of Sheffield/Chesterfield.
Many thanks to anyone who replies
Grandadmark
Wed Sep 28 2016, 10:21am
Presumably you have checked the Other Services garage ratings?
For the C6, it might be worth travelling further (than 10 miles) and getting a specialist who knows the C6.
Could you increase your specified range?
regards
Wed Sep 28 2016, 06:26pm
That's very true. You will need a competent garage for a start, who have serviced or repaired a C6 before or at least has some idea of what to expect from a C6. On the forum recently there was talk from a forum member who was told by a Citroen garage that they needed a "special tool" before the timing belt could be replaced for example. We're all still scratching are heads regarding the turn of phrase used!
grandadmark
Fri Sep 30 2016, 09:00am
Member No: #508
Thanks for the suggestions. I have got two garages within 50km I am going to investigate
Regards Grandadmark
