Front n/s and o/s shock replacement.
speedfix
Thu Jan 15 2015, 07:29pm
Replaced both shocks not struts as some folk have in the past called them.
Job took much less time than doing a leg removal as some do.
The top wishbone bolt removal and the drive shaft nut is the key to a simple job.
100,000 miles and a five year old car with the original later type struts but what a rusty state they were in above the boot.
some pics :
Junksleeper
Tue Jan 27 2015, 07:45pm
Member No: #1605
Where did you source the parts from Speedfix? and how much were they?
speedfix
Tue Jan 27 2015, 10:49pm
Genuine PSA UK Shocks ordered complete with amvar valves and sphere seals.
Price each a little over £228-00 + vat.
Did have a case logged with Citroen to complete a delivery.
Hope this helps.
Junksleeper
Wed Jan 28 2015, 12:50pm
Member No: #1605
Thanks speedfix - got an advisory on the MOT this week for the front offside so will prob get both done sooner than later. Would it be a relatively simple job for a competent independant garage mechanic?
speedfix
Wed Jan 28 2015, 10:56pm
Should be ok if they have worked on Citroens in the past.
Four post hoist IMO is best for the job.
Main points:
Remove LDS reservoir cap.
Slacken spheres a tad under pressure.
Depressurize system.
Remove ignition key.
Remove front wheels and remove drive shaft nuts.
Drop rear top section of wheel liners.[to remove top wishbone bolt]
Remove spheres and all fixings for the shocks and remove.
Change tank and fluid if a magnet is fitted by owner on milers.
