wont start |
mercuryrv
![]() ![]() ![]() Member No: #1848
Thank you for completing this story, good news that all is now up and running again, ENJOY!!! | ||
ststech
![]() ![]() ![]() ![]() Member No: #1845
this car is driving me mad and will soon be scrapped ! went out this morning cranked starter wouldnt start about 5 seconds did same again twice then on 4th attempt fired up fine but did notice radio had gone back to the start folder where as it usualy resumes where it left off may have no relavence on to cooling system looked at coolant tank all fine no bubbles coolant stable took car for an intensive drive mainly around 3k rpm using tiptronic to get temp up returned home checked coolant reservoir bubbles flowing through small return pipes and coolant level high unscrewed cap slowly and coolant poured out bubbled a bit then settled down but bubbles still coming through return pipes see here - Click Here - |
I had the same symptoms many years ago, on a Renault 4. It was gradually worse until the tank lid (a glass, actually) bursted, Head gasket problem, I changed gasket once a year after that (for me: low cost, much work, but down to a couple of hours after some rounds). The basic reason was the "wet" cylinders having sunk a little in the block | ||
ststech
oh dear if it is head gasket and not something else wrong or something i am doing wrong i will send the tax back then take it down the road and watch them crush it!! video them doing it and put on youtube i have had varios citroens hundreds since 1991 this is the worst............ then find me a nice clean xm but i have funny feeling that it is ![]() so far the [%*^#@!] thing has had a new coolant thermostat tank old one was split a new header tank cap all glow plugs replaced new uprated battery so it may look like a sad loss of one of very few c6's being crushed the annoying bit is she runs and drives lovely |
You would be really stupid to crush it given the cost of parts. Bumpers and headlights alone would raise circa £2K used.......... |
speedfix
![]() Member No: #1043
Sorry to hear of the perstant prob. Re first starting from cold could well be the cylinder hydraulicing due to water seepage from head gasket or more so IMO from a cracked head that when left for long periods dribbles water into the bore. The crack would open up when hot and that could be the bubbles you see after a spirited run. Now which head could be the problem, I would go for the head that had the injector prob no 4, may have water damage to injector from being left for a long period that has now cleared with injector cleaner. To be sure first a pressure test over time, then a cylinder leak test to confirm which head is the problem. As for the XM if you decide to go down that route, I hope you have less problems than I did with mine after spending £s on it. New owner ran it for miles trouble free! I returned to the cx turbo 2 saloon and estates the last one covered 360000+ miles before the rust got to the body. |
ststech
is there anyway that this could be caused by something other than head or gasket or both could the poor starting be related just find it strange how once started she runs beautifully i dont know if this has anything to do with it but i followed the drain refill instructions well the refill part upon replacing the coolant thermo tank undone heater matrix bleed screw but could not see one on the radiator so i just pulled the small pipe at top of radiator could there still be air in it and would this cause the issues i have which is coolant loss slight and what you saw in the video i posted the urge to want to crush it is because i love the car so much but so upset with it and christ knows how much it would cost for a gasket repair how much work is involved as there is no repair literature for this engine available not even a haynes manual for the jaguar land rover variants that share this engine and my local garage wont touch it i asked them about doing a timing belt he said no any help with these issues would be greatly apreciated help help help thanks simon |
Never had these problems on DS, CX, XM, they were self-bleeding. But again: the old R4 also made such symptoms after a refill, due to air in the system that expanded. But that of course solved itself after a few days of driving. If it is a head gasket issue, starting problems may be related if coolant leak indto cylinders(?? (not sure of this). My advice: Be brave and get a professional diagnose ! | ||
speedfix
"could not see one on the radiator so i just pulled the small pipe at top of radiator could there still be air in it and would this cause the issues i have which is coolant loss slight and what you saw in the video i posted" The small bleed pipe is ok to bleed the radiator. In some rare cases air can get into the coolant system when a system pressure test shows it ok. How can this be, with some water pumps after time the seals will leak air back through the seals when the coolant cools leaving a vacuum in the system. when hot the air in the coolant can show its self through the bleed pipes and expanding coolant will then leak out giving the head gasket the impression of a incorrect fault. Better to confirm either way with a pressure timed test etc. When time permits I will replace the timing belt on mine early next year [100000 miles]together with water pump and roller tensioner kit. 160000 miles imo this is to long for the water pump and original coolant. PS Simon have just looked at your MPG does not look good for a 2.7 c6. this may reflect a failing! |
ChrisHunter
what fuel do you use - best premium ,hopefully - eg: Shell V-power ... ? if previous owner used standard supermarket fuel, with most of the finer things left out, maybe that's the problem ? NB: we find mpg better with premium - so, ironically, it costs less, as well as going & sounding a whole lot better... |
ststech
worst case scenario if hg is failed which i would say the front bank what sort of cost to have it fixed obviously change timing belt at same time and any recommendations for someone who is familiar with this engine and would do it local to me in somerset if too expensive it will go down the road and be cubed ! |
Black_Lemon
![]() Member No: #1461
I had a problem which turned out to be worned bearings in the starter. I had the starter serviced with new bearings and now is starts quick and easy as it should. The worned bearings in the starter drains the battery. | ||
dcchurchill
Do you have an update on your problem ststech? | ||
Nikolaj
![]() Member No: #4047
This beeing an old post, I guess either the head gasket has been replaced, or the car scraped. I have a little experience in blown head gaskets, since I managed twice, to buy a car with a blown head gasket, and beeing in "denail phase" for up to a year afterwards, trying all kind of fixes before eventualy changing the head gasket. First was a Clio petrol that used a bit of coolant, being a little difficult to start when cold, and ran uneven for the first min after start, then averything fine, and warm start fine. Cause: head gasket leed coolant to enter 1 cyl when cooling down, after skimming head and new gasket, everything fine. Second C5 HDI, always started an ran well, but used coolant, and had bubbles in the expansion tank, I didn't believe a head gasket problem, since it ran so well, but there was no doubt when looking at the head gasket, head also skimmed due to a small grove, the maschine shop said, that they saw the head gasket as a service part, since thay always got the heads in for skimming at around 200-250.000 km. To never end up in this situation again, I bought a Co2 leak test kit: - Click Here - Then there's no doubt. My collegue bought C5 HDI with 232.000 km on the clock, and it tested fine, but around 250.000km the gasket gave up, so maschine shop might be right, ![]() |
