Take off Speed? |
Tickle the throttle first then push and everything works perfectly! G |
smihaialex |
Yes G, I sometimes do that aswell and it does work, but it's kind of weird to develop this habit, don't you think?!? Cheers, Sam |
Dekidex |
Member No: #1471
gmerry wrote ... Tickle the throttle first then push and everything works perfectly! G What I do is power brake and then the C6 takes off the way it should. |
speedfix |
"gmerry wrote ... Tickle the throttle first then push and everything works perfectly! G What I do is power brake and then the C6 takes off the way it should." Hope the sprag will last ok if it has one!!!!!!! |
Dekidex |
Member No: #1471
speedfix wrote ... "gmerry wrote ... Tickle the throttle first then push and everything works perfectly! G What I do is power brake and then the C6 takes off the way it should." Hope the sprag will last ok if it has one!!!!!!! What's a "Sprag"? |
BruceB |
Member No: #234
Dekidex wrote ... http://en.wikipedia.org/wiki/Sprag_clutchWhat's a "Sprag"? |
speedfix |
The sprags are often refered to as one way roller clutches, they can cause rough changes and hold creep drag characteristics when failings on auto boxes. Don't know if the C6 auto has them or not. |
