gear knob replacement |
bigmario |
These days I have to replace the shift knob because the skin is damaged, but can you tell me how to disassemble? I have to unscrew or pull out or is there something else hidden? Thanks Sorry my C6 is a 2.2 HDi model with manual gear! |
stefan063 |
Member No: #918
You must take of that shiny thing were says C6 (whole shine part, not only C6 black circle),with your fingernails. Then you must stretch knob at the same time left and right. You will see silver clip on top and red clip below that holds the knob. Put it away, and vuola!!! | ||
bigmario |
Hi Stefan and thanks for the reply, but I did not understand how to remove the top cover. It is where the numbers are printed (the 6-speed + back); this cover is chrome plated and then immediately below (all around the knob) is the leather ruined I should change! Sorry for my English! |
stefan063 |
Member No: #918
Remove this part where red arrow shows... That is the first part. The rest I have written it in my first reply... |
smihaialex |
Hey guys, the man has a manual not an auto gearbox... Different knob... Simmilar to C4 2.0 HDi 6+1 & C5... The top (where the numbers are) comes off and if I remmember correctly there are no screws... You just have to rotate it and it comes off (counter-clockwise for 90 degrees, if I remember)... | ||
bigmario |
smihaialex wrote ... Hey guys, the man has a manual not an auto gearbox... Different knob... Simmilar to C4 2.0 HDi 6+1 & C5... The top (where the numbers are) comes off and if I remmember correctly there are no screws... You just have to rotate it and it comes off (counter-clockwise for 90 degrees, if I remember)... Infact! Is as you say! But I have to remove the cover to lift the top (that I think is blocked pressure) and then I can turn the knob? Right? Anyway thanks for the answer! |
smihaialex |
Yes! Something like that! I will check with my service guys and get back to you... | ||
