When pulling away...
Sun Jul 08 2012, 04:02pm
Member No: #82
I've noticed that when I'm at the lights, in neutral, when I put it into gear I tend to put my foot on the brake. What do you do? Just flip it into gear and give it some juice? I'm sure using the brake has no effect as by the time the car starts to creep my foot has left the brake anyway. It's just force of habit I think.
ped
P.s talking about an auto box
Chevrons
Sun Jul 08 2012, 04:50pm
Member No: #85
Ped,
Why put it in neutral at the lights?
It's an automatic gearbox.
Sun Jul 08 2012, 05:15pm
Member No: #82
If I'm there for a while I tend to put it in neutral.
The question also applies for pulling away from neutral regardless of location.
Sun Jul 08 2012, 06:34pm
Chevrons wrote ...
Ped,
It may be but sitting at the lights for a long time means that the valves are by passing so heating up the fluid
Ideally it should be in neutral with the handbrake applied, not in drive with your foot on the brake.
Sun Jul 08 2012, 11:27pm
Member No: #82
So what do you both do?
Mon Jul 09 2012, 07:24am
Both
Depends on how long the lights are going to be against me. 3-4 way temporary lights are the worst if you hit them as they just turn red, then it's out of drive and handbrake on for me
Ordinary traffic lights need a judgement call based on knowledge of the area and the usual length of time your sitting at red.
drummond
Mon Jul 09 2012, 10:22am
I haven't used the handbrake since I was last on the ferry to France with it- about February?
Chevrons
Mon Jul 09 2012, 10:29am
Member No: #85
Ped wrote ...
I put it 'Drive' and drive it; Never use neutral.
michaelb
Mon Jul 09 2012, 11:17am
Member No: #14
I put my Alfa 166 into neutral because there was an unpleasant 'thrum' resonance when it was 'straining at the lease'.
I never put the C6 in neutral because there was little engine creep to fight, no noise and leaving it in Drive puts less wear on the gearbox. It probably burns a slight bit more diesel because you are counter-acting engine creep but that is a lot cheaper than rebuilding the gear selectors.
I always put my Quattroporte in neutral, even before I roll to a stop, because it reduces clutch wear. It being a robotised traditional clutch and gearbox.
Mon Jul 09 2012, 02:17pm
Lads,
Re. Michael B.'s comment. I had an automatic XM diesel and I preferred to stand in neutral due to the resonance. The XM would strain at the lease (as Michael says) against the brake in drive and when you released the brake the car would immediately move forward. In the C6, I notice that if you release the footbrake immediately in drive, from a stand, there is a time lag before the car moves - like as if the converter is filling. When reading up on Aisin Warner transmissions, I remember seeing a reference to the box selecting neutral at a standstill with a brake input. Could it be that the converter drains in this situation. To me it certainly feels like the car is not trying to push against the brake and why I'm comfortable to leave it in drive when standing at traffic lights; something I felt was punishing the XM.
Regards,
Mon Jul 09 2012, 07:53pm
Member No: #82
Sorry guys not wondering weather you engage neutral or not but your pulling away procedure from neutral.
Mon Jul 09 2012, 08:27pm
Sorry Ped,
If I do have car in neutral, when I engage drive I hold on footbrake and then release footbrake to control start from standstill.
Regards,
Mon Jul 09 2012, 09:00pm
Member No: #82
Thanks Phil. Me too!
ciao_chao
Mon Jul 09 2012, 10:39pm
Member No: #518
Where predictable, I'll slot it into neutral and pre-emptively engage D/1 when I know they're about to change and ease off the brake, this allows the converter to fill and I'm ready to go when it's green. For example at controlled roundabouts, I'm watching the light reflected off the shade for the other direction rather than my own light.
Additionally, I try not to stop at lights at all, I hate all the faff of it, so if it's just turned red a long way away, I'm off the gas immediately. Usually that gives ample time for the lights to go green again. If it's still red, I'm naughty and tend to be creeping the car forward, so often I'll pull up a few feet behind the line and I'll be a few feet the other side of the line by the time it's green.
Leo
Tue Jul 10 2012, 08:31am
Member No: #94
I agree with Phil C.
I read something similar about the auto box selecting neutral and it certainly feels as if there is no engine pull when stationary with the footbrake on - very different in my Merc 300GD Auto - when I select neutral in that at a set of traffic lights the engine revs. rise as the strain of pulling is released.
Leo
