Everything I have found about the RT4/5 and USB (and phones and Bluetooth)
pclark
Tue Jul 24 2012, 07:07am
Member No: #3
As michaelb says you undo the two Torx screws (T10 from memory?) which are in the small holes at either side of the head unit facia panel. You will need a long torx bit or screwdriver type as the screw heads are too recessed for a normal socket set type bit. The head unit then simply pulls out. The 'extractors' are probably for RT4 when used in other Citroen/Peugeot models.
Dapprman
Tue Jan 28 2014, 10:35am
Member No: #710
Necro time ...
I got a cable fitted to my RT4 unit today (well colelcted the car today). If I put a pen drive in I get a Recognising CD message (as you do with a firmware/speedcamera/map update), but then nothing. The drive is set up as follows
D:\>dir
Volume in drive D has no label.
Directory of D:\
19/03/2009 10:39 55,731 BUILTINS.OUT
19/03/2009 10:40 77 BUILTINS.OUT.inf
28/01/2012 12:03 111 POI_VER.POI
27/01/2014 13:50 <DIR> UPG
27/01/2014 13:49 <DIR> CMD
D:\CMD>dir
Directory of D:\CMD
27/01/2014 13:49 <DIR> .
27/01/2014 13:49 <DIR> ..
13/11/2009 11:12 7,566 CONFIGFLAG.CMD
and nothing in the UPG folder. Am I missing some thing ? I'm running firmware 8.31 so could this be an issue as well (i.e. too high).
Cheers for any help
Dapprman
Tue Jan 28 2014, 12:11pm
Member No: #710
Now sorted - was missing the POI_UPGRADE.CMD file from the UPG folder - if I'd just uncompressed the Mirascripts zip on to the USB drive it would have been fine
Go to page   <<
