Suspension gone hard - crashing on bumps |
| Author | Post | ||
![]() ![]() Member No: #21
Hi Smorphet et al, I changed out my two front suspension spheres. They both make a rattling sound when shaken. Can't imagine this is correct. Now have two Monroes SP8133 (50 bar) fitted up front. Will test drive and if still not correct, will try the front stiffness sphere next. Regards G PS, will make up a sphere tester at some stage. |
Junksleeper
![]() Joined: Feb 28 2014 Member No: #1605
I have a very similair problem on my 07 plate 2.7 exclusive, ie hard suspension at low speed especially over speed bumps and the like and after taking it to local Citroen/Peugot specialist was informed that as well as having the aforementioned smorphet's experience of a diagnostic showing a fault from a front static pressure sensor, the rear nearside suspension cylinder was leaking and needed replacing at a cost of £350 (part specially ordered from France)- sharp intake of breath! I've read on a few C5 forums that these cylinders have seals and gaiters that are replaceable for a lot less than £350 notes. I've also read that they are supposed to bleed to lubricate the cylinder. Can the same be said for C6 suspension cylinders? The garage state that without replacing it , it will not be possible to trace the suspension fault. I'm almost resigned to spending loads of money and ending up getting nowhere in fixing the initial problem. I'm not overly keen on replacing sensors unnecessarily. There seems to be conflicting advice as to how to actually test the spheres which would seem to be the easiest and quickest way of eliminating or tracing faults. Any ideas out there? Any help from you guys will be very much appreciated.
Lots of posts already on suspension spheres which are likely to be the problem, not a sensor. | ||
dsharples
![]() ![]() Member No: #119
Dave, absolutely agree. My experience is that some dealers and specialists are adamant that the grey saucer-spheres don't fail or decrease in pressure over time, because they "have never seen any". Many C6 owners can state the reality is quite different. I can only assume that its because many C5/C6 owners cars are now reaching the age (outside of dealer maintenance/warranty periods) where the ride is becoming truly awful, and are seeking a solution, or that the cars are now in the hands of enthusiasts who know its not right... And of course, sphere pressure/failure can't be detected by Lexia/DiagBox. So this could be a new "learning" for all... |
Mike H
![]() ![]() Member No: #53
I agree, 8 years 88k kms. Per these posts I had all spheres changed to IFHS kit. Very reasonable price Much improved ride Do this first. You can send the old set for regas. Mike |
![]() ![]() Member No: #954
"Air" bubbles in LDS may be gas after leaking/exploding sphere. This happened in a DS for me. Grey saucers will do this more often, due to the built-in puncturing device. I have ordered 3 new front IFHS spheres just to be sure: have a feeling that pumps in the corners are too hard, but floating is quite DS (less that 5 years, 72 000km) | ||
ststech
![]() ![]() ![]() Member No: #1845
i have just replaced both front corner spheres with munroe spheres. as i was getting bad crashing on bumps and potholes, now this has disapeared the ride is so much better no more crashing! but i have ordered a set for the rear not sure if they are faulty dont notice any crashing but the ride at the rear is very floaty like being in a boat! any ideas anyone? |
Kaloteck
![]() Member No: #1271
Like being on a boat, yes... that's what is all about, sort of... | ||
TycoonX
![]() Joined: Aug 15 2012 Member No: #988
Monroe spheres..and any other makers are not equal to citroen spheres.. only citroen spheres can make over 200-300 000km | ||
ststech
Kaloteck wrote ... Like being on a boat, yes... that's what is all about, sort of... Well i suffer with severe Emetaphobia fear of vomiting so there is no way i would ride in the back of my c6 at the moment or would i take anyone who is prone to travel sickness! so i am going to replace all 7 spheres
