C6owners :: Forums :: C6 Support :: C6 Navigation questions and Map or Software Updates
Finally got my new RT4 under warrenty
neal2175ds
Wed Jan 25 2012, 10:14pm
So after a few failed attempts i finally got my new RT4 fitted today under warranty. Started the car, tried to adjust the climate control... nothing on the screen. No climate display at all.. Dark setting doesn't work, cant see if it has the latest maps installed and for some reason this one has no circular chrome bezzle around the switches in the middle. Left the car with them... Only upside I drove a C5 Exclusive.... very quiet, much less road noise, i guess its the tyres which are a higher profile 55 section and narrower too. Not a beautiful car like the C6 though..... Argh, got that off my chest !
Extant
Thu Jan 26 2012, 01:23pm
Mine is going back again. The sat nav has now lost sight of the gps satellites.
Thu Jan 26 2012, 01:31pm
Because I had seen so many problems reported with the system over at C4owners, it's one of the reasons I went for a Lignage and kept my TomTom
You have my sympathy guys and good luck getting them working.
neal2175ds
Thu Jan 26 2012, 06:33pm
Got the car back and its all fitted. It seems to work. BUT now when it boots up it says Magnetti Marelli instead of our beloved chevrons on the screen. Cosmetic I know but it looks kind of shabby... It has no chrome bezzle, again cosmetic but flippin annoying. The dealer cannot display the software release, and are told by Citroen not to change anything with the unit, leave it as it is. I have updated the UK maps as they said i could do this and it went all ok, but the speed camera disc is not loading, I need to check i am doing that right though as i just put the CD in and it does nothing.
Extant
Fri Jan 27 2012, 09:06am
Neal, I had the same thing with the display when my replacement unit was fitted. I took it back and the dealer rectified it. Given what you say about Citroen's recommendation, I'm now wondering if this is why it's just lost contact with the GPS satellites.
neal2175ds
Fri Jan 27 2012, 09:33am
Interesting..... I think i will see if i can get hold of the chap on the forum here who specialises in these sat navs and get some advice about all this.
m3mpower
Sun Feb 05 2012, 10:00pm
Member No: #662
neal2175ds wrote ...
Hi Neal
Regarding boot screen showing "magneti Marelli", Citroen should sort that out, reprogram the VIN and the unit should show "Citroen" on boot screen
With the chrome bezel in the middle, usually the black units do have chrome
And with speed cameras, you need to update the firmware first, as these won't work unless you have 8.11 and up.
But i wonder why Citroen told you not to update it, they should do it for you.
neal2175ds
Mon Feb 06 2012, 04:23pm
Its in to the dealer Thursday... They need it for two days while they update the sw and test it. The unit is black but has no chrome bezzle in the middle.
On a serious note I'm sure all this sitting around on tick over for hours and hours day after day (what with all the visits) while things are changed and software updated is doing my particulate filter the world of good.
On a pleasant note now.. i met three customers today in a car-park prior to a meeting and they all drooled over the C6. One has a Porsche, one an Audi A6 3.0d and the other an A4.
m3mpower
Tue Feb 07 2012, 11:33pm
Member No: #662
2 Days to update the software and test it?
Wow !
neal2175ds
Wed Feb 08 2012, 10:12pm
yep !
