C6owners :: Forums :: C6 Support :: C6 Navigation questions and Map or Software Updates
How do i know what software my NaviDrive is running?
neal2175ds
Wed Oct 26 2011, 06:35pm
Hi there, I am sure someone who has owned a C6 longer than me knows the answers to these questions...
How do i find out what software release my NaviDrive is running?
Where do you get the updates from? Can they be down loaded or must they be purchased on CD?
Is it recommended to update the software to the latest release to fix known bugs and does this normally go smoothly?
In addition it would be cool to have a rather more up to date set of maps. Where do you get updates for mapping from?
Many Thanks
Neal
m3mpower
Thu Oct 27 2011, 12:19am
Member No: #662
Hi
To know the software version of your navidrive you need to:
Press and Hold Menu, then look for "unit description".
Yes it is recommended to update to the latest software and if you do it carefully it should go smoothly.
Ingolf
Thu Oct 27 2011, 08:24am
Hi Neal!
I recently did an upgrade on my 2007 RT4 system. Bought the complete package of 13 cds for the entire Europe, as they don`t offer a map update exclusively for Scandinavia. Too bad really, but again, we`re an exclusive group of people driving C6 up here.
Installation went without problems, though the engine must be kept running, to avoid the economy mode. Which meant the entire evening, driving around with the car. A much more preferred way compared to keep it running outside my house.
Ingolf, Oslo
neal2175ds
Thu Oct 27 2011, 11:02am
Guys,
thanks for your responses... so I did the checks and got a whole list of stuff back... can you explain
against the display where it said SW Version_unit by pressing the ok i got the following;
- 8.11.A-4
- CD3239
- sw version 11/03/09
- BR:10
- CD_FW:UEJ2
- FP 11.04.06
- GSM 5.43
- RD:671A40
- 9d 8h6
Any idea what that all means?
I assume my maps are out of date, so If I order the current maps for the UK and speed cameras (thanks for the link) does this remove the maps for Europe that are already installed?
eke
Thu Oct 27 2011, 11:20am
Member No: #624
- 8.11.A-4
This is the system software version and it means version 8.11. There is newer one for RT4 available, version 8.20.
neal2175ds
Thu Oct 27 2011, 11:22am
Thanks... where do you get that from?
drummond
Thu Oct 27 2011, 02:10pm
If you order it in euros it's about 13% cheaper, by the way. The thread by ingolf has euros as well as £.
Tim
neal2175ds
Thu Oct 27 2011, 02:29pm
Another top tip... thanks. BTW how do i find out how old my mapping is? And where do i get the 8.20 software
m3mpower
Thu Oct 27 2011, 03:07pm
Member No: #662
neal2175ds wrote ...
Hi,
Regarding 8.20, you order it from Citroen dealer, the part reference is 1606858680 and costs £33.08
Regarding the maps:
if you want to know the version:
Go to Menu, Maps, Map data base description, you will get the list and versions of maps installed
The latest maps for Europe available are version 2010-11 and the latest speed cameras version available is August 2011
Best regards
Thu Oct 27 2011, 05:02pm
You can order Nav maps from this official Citroen site;
http://citroen.navigation.com
Dapprman
Sat Nov 12 2011, 03:06pm
m3mpower wrote ...
Hi
I've just tried this in my 2007 car and I did not find any such options. Was there another way on the earlier cars ?
m3mpower
Sat Nov 12 2011, 03:50pm
Member No: #662
Dapprman wrote ...
m3mpower wrote ...
Hi
Hi
Press and hold menu, select "radio telephone diagnosis", "unit description"
Dapprman
Sat Nov 12 2011, 06:03pm
Cheers - looks like you can only get that info with the ignition on and the engine off, on my previous attempts I had the engine running.
m3mpower
Sat Nov 12 2011, 07:06pm
Member No: #662
Dapprman wrote ...
Hi
It does not matter if the engine is on or off, this method works anyway
On your previous attempts you did not select the right option
Dapprman
Sat Nov 12 2011, 10:30pm
m3mpower wrote ...
Dapprman wrote ...
Hi
Nope did the same thing as before, but this time I had not started the engine. This was what confused me.
