Windshield Wipers dead |
| Author | Post | ||
CitroSuède
![]() Joined: Feb 12 2014 Member No: #1582
Sometimes I wish I still had my XM wagon. Wipers just won't operate but the screen tells me if I've got the automatic wipers on or off, but no action at all. They died on me just before summer once but woke up again and then just worked. Now the car has been parked during the summer and today I started it up and guess what? No wipers... |
JoHoHa
![]() Member No: #6087
Hello CitroeSuede, I reckon the shaft is stuck. You can try to work out which of the two it is, but I’d always do both sides. ! Mark the wiper arms on the shaft ! - Remove the motors, - Loosen the clips at the back, - Carefully remove the black cap. Take care with the bridge containing the carbon brushes and carefully pry it out with a small screwdriver. Then remove the spring washer from the shaft on the wiper arm side and push the shaft out backwards. Clean it and apply seawater-resistant grease. Fit a new O-ring (NBR, not NPDM). I’d try to keep the white grease and apply it evenly to the clean parts. I suspect it’s grease containing PTFE, but I’m not sure exactly which type is compatible with the plastic of the gear. Reassemble everything and you’re done. Don’t fit the wiper arms straight away after installation! First, let the motors find their zero position! Then fit the wiper arms according to the markings. You may need to adjust them slightly. I was really worried at first too. But as the motors need protection in case the wipers freeze solid in winter, it’s probably nothing serious. Regards from Hanover Jochen |
JoHoHa
Entry from my maintenance log: As expected, the windscreen wiper simply wasn’t working. As I didn’t have time at first, I only drove when the weather was forecast to be dry. When dismantling the left-hand motor, it turned out that the main shaft had simply seized up. Both motors were completely dismantled, cleaned, and the main shafts were greased with seawater-resistant grease (Ravenol) and the O-ring replaced. I deliberately left the white grease used to lubricate the plastic (PTFE?) gear and redistributed it. The composition is too unclear (to me) for me to simply want to replace it. I scraped out the insulation slots in the collector with a sharp knife and cleaned them with brake cleaner. NOTE: The carbon bridge is simply slotted into the housing. After releasing the clips and lifting the cover slightly, it can be prised up a little with a small screwdriver. However, during reassembly, it isn’t pressed down far enough by the cover. This results in a scraping noise from the carbon brushes. To fix this, insert a thin object through the white diaphragm in the cover and press the bridge down as far as it will go. The noise will then (almost) disappear. Fun fact: The drives do not have a crank mechanism for the wiper arm. The motors – which are electronically controlled – rotate to their dead centre and back. This means two stops per wiper movement. If this works reliably over the long term without damaging the carbon brushes, there is no need to worry about additional strain during intermittent operation. |
CitroSuède
I'll definitely should have a look at that, the car has been sitting outside for long periods, so those axles getting stuck won't be that impossible. | ||
