Brake Issues |
| Author | Post | ||
malpatrinos
![]() ![]() Member No: #5830
Bit of history to this, so get comfortable! October 2025:
May 2026
Could a binding calliper (don’t know how long it was doing this) have damaged the new discs? What are C6 brakes supposed to feel like? |
Unlucky Yes a binding caliper could and most likely will damage a new disc. The heat generated will warp the disc and it sounds like you'll need to replace that as well. Generally, I find C6 brakes are a little soft even with new discs and pads. I'm not sure if it's the system itself or the brand of pads used. Either way, it takes a long time to wear them out to try the next set |
![]() ![]() Member No: #4944
Did you change it yourself? | ||
sandiego77 wrote ... Did you change by yourself? Yes, I do all my own maintenance. |
malpatrinos
sandiego77 wrote ... Did you change by yourself? No, I didn’t - one garage (a Citroën specialist) did the discs and pads in October and a local mechanic did the MOT repairs in May. I’m taking it back to the MOT garage this week as they’re local. |
