Front Shock Absorber - where to find??
rozen77
Wed Jun 03 2026, 12:09pm
Member No: #5897
Hello Friends
Someone know something about new Front Shock Absorber - where to find??
Its impossible to find everywhere
Thanks
Guy
Wed Jun 03 2026, 01:28pm
rozen77 wrote ...
2.2 or 2.7/3.0 HDi?
I did find this - Click Here - but you need to check the part number and car model
This one says it is for a 2.2 - Click Here -
Mel_h
Wed Jun 03 2026, 03:01pm
Member No: #5972
2.2 or 2.7/3.0 HDi?
Sadly, when you go to select which side, both are out of stock. I do not believe that there are any new in stock, anywhere (worldwide). Secondhand ones are almost impossible to find and many will be partway through their life so only a temporary fix (if you can find one).
Wed Jun 03 2026, 05:36pm
As others have said, no longer available new. Used if you can find them (I have two sets but I'm keep those for myself ).
Refurbished are available from Poland via Tomek Novak on facebook - Click Here - His warranty conditions are a little onerous for only three months but you can always take the risk of not complying and hope for the best. I haven't tried one yet and can't vouch for the quality but we can't be choosy at this point.
Here's hoping Citroen see sense and commision the OEM to make a batch soon.
malpatrinos
Thu Jun 04 2026, 05:45pm
Member No: #5830
I’m on the lookout for AMVAR struts too. Is there any mileage on trying via CCC and other national Citroën clubs to try and convince Citroën to get a batch made?
M2dis
Sun Jun 07 2026, 10:29am
Member No: #3475
malpatrinos wrote ...
I know that Chevronics wrote directly to Citroen and CCC last year, they posted about this on their Fcebook page, but nothing has followed yet, probably didn't get any answers.
tpr
Mon Jun 08 2026, 09:54am
Member No: #5543
I'm getting worried -- I don't need front struts now, but my C6 (2.7HDi) is close to the mileage at which both struts needed replacing on my C5X7, around 95000. (You could get new ones from Citroen then.)
Is there an option to use non-AMVAR struts on a 2.7HDi C6? Can you use Lexia to tell the suspension computer that it does not have AMVAR? Are C6 2.2HDi non-AMVAR struts the same as C5 ones?
Dan595
Wed Jun 10 2026, 01:12pm
Member No: #299
tpr wrote ...
To the best of my knowledge, 2.2 struts are the same as C5 X7 ones.
I would investigate Polish remanufacture before thinking about how possible it is to fit non-AMVAR struts to a 2.7 - there would be a lot to change, including the spheres. I do wonder how much is specific to AMVAR struts and how possible it is to take a new non-AMVAR strut and fit the old AMVAR gubbins to it.
tpr
Sat Jun 13 2026, 08:45am
Member No: #5543
Thanks; I didn't realise you need different sphere pressures too, although that makes sense.
Are new C5X7 / C6 2.2 struts still available? (Re your suggestion of investigating moving the AMVAR gubbins onto a new strut.)
Polish reconditioning does sound like the best bet, even if it needs re-doing every couple of years.
Dan595
Sun Jun 14 2026, 08:26pm
Member No: #299
Re: spheres, I presume they are different as 2.2 spheres have damper valves in them.
I fitted a new strut to my 2.2 a couple of months ago. Was easy enough to find one. There are also aftermarket ones, no idea if they are any good - £100 or so each.
