Firm suspension after Pleiades sphere recon
tpr
Mon May 04 2026, 01:15pm
Member No: #5543
Hi all
As recommended by Robert at BL Autos after finding my (presumed original) sphere pressures down a bit, I had my spheres reconditioned at Pleiades last week.
Now the ride does not seem right; I am feeling all the bumps. It was especially bad on a straight and fast road that is not entirely smooth (A30 from Sutton Scotney to Stockbridge).
So today I fired up the ol' Diagbox, which I don't have much experience of using. No suspension or AMVAR faults reported other than U1205 lack of communication with the steering wheel angle sensor. I tried some actuator tests. The AMVAR ones seemed ok, although with a much more noticeable difference on the rear than on the front. The rear firmness one was ok. The front firmness one did not make any difference; it seems hard either way. (This is judged by trying to bounce one corner or end by hand.)
My guess is that the recon of the front centre sphere failed and it is now locked hard with no pressure, so switching it in for a soft front does not make any difference. Is that a reasonable guess?
Not casting any aspertions on Pleiades; we all know that anything can happen in Citroën ownership and it usually does. But I just wanted to try and figure out what the problem might be before making the two-and-a-half hour each way trip over there again.
I guess I could save the trip if I could find someone more local to just replace that sphere, and send the recon one back to Pleiades to see what they think of it. But my friendly local garage isn't very happy with doing suspension stuff where I would need to turn up with the Diagbox/Lexia to depressurise then repressurise and bleed. Any ideas for someone more local to me in Newbury (M4 J13)?
Tue May 05 2026, 06:54pm
Your diag seems to be sound and the centre regulator sphere appears to have failed after regassing. I've had a 2.2 in for repair with failed regassed spheres so I can confirm it happens unfortunately.
I don't live near you to help but I can send you a used sphere to change if you're up for it?
Wed May 06 2026, 10:58am
I had an experience with a regassed sphere (on a DS) that suffered an internal explosion. Nitrogen gas all inside the system with interesting and surprising effects. Healed itself, but of course i needed a new sphere.
tpr
Wed May 06 2026, 11:04am
Member No: #5543
Thanks Mike, but I think I need to find someone else to do the actual change.
Wed May 06 2026, 05:18pm
tpr wrote ...
No worries. The only garage I know closer to you would be Southways Automotive in Fareham but I suspect he'll be well booked up. There's no harm in asking
tpr
Fri May 29 2026, 02:48pm
Member No: #5543
An update:
I went back to Pleiades, and the front spheres were all at exactly the right pressure. Ride seems fine now; maybe I was just being over-fussy on a bumpy road. So all happy now.
(Back to BL in a few weeks for MOT, service, and possible EGR valve problem.)
tpr
Mon Jun 01 2026, 09:01am
Member No: #5543
Also, something I learnt there:
To do something like remove/replace a sphere, they don't need to depressurise using Lexia. They just put it into low position, turn off engine, then lift the car up leaving the wheels dangling (loosen LDS filler cap first), and there is virtually no pressure left in the system.
Mon Jun 01 2026, 12:38pm
tpr wrote ...
Thanks for that tip, I'm sure it will help others in the future.
