CORRECT BRAKE FLUID for C6 : ATE SL or ATE SL.6 ?
citroenroen1
Sun Nov 02 2025, 05:54pm
Member No: #5495
The C6 master cylinder reservoir has ATE on the reservoir: so I will use ATE Brake Fluid when I flush / renew the brake fluid.
Which type of ATE brake fluid is CORRECT for the C6 ?
ATE SL (Dot4) or ATE SL.6 (DOT 4) ?
The factory download says to disconnect the battery : Why would it be necessary to disconnect the battery ?
Sun Nov 02 2025, 11:21pm
ATE SL will be adequate for the operating temperatures you will be running the car in. SL.6 has a lower viscosity which will help in cold climates.
As SL.6 has a lower viscosity it is also recommended for ABS, ESP & ASR equipped vehicles like the C6 but my interpretation of the specification is that only becomes a factor at low temperature.
If you can get SL.6 at an acceptable price, go for it. If not, then SL Dot 4 will be an adequate alternative for you.
citroenroen1
Mon Nov 03 2025, 04:24pm
Member No: #5495
Regarding CITROEN download which states " disconnect battery " :
WHY would battery need to be disconnected ?
Mon Nov 03 2025, 05:48pm
citroenroen1 wrote ...
For safety, but the option not to is down to you.
