Engine mounts and transmission mounts |
| Author | Post | ||
rozen77
![]() Member No: #5897
Hello I have 3.0 Hdi I can't find in the part catalog description of Engine mounts and transmission mounts and parts number, can someone help me with numbers and diagrams? Thanks Guy |
here you go.... - Click Here - |
rozen77
Thank you friend ???? |
rozen77
Thanks you for the link. can you help me to find which Mounting engine and Gear there Is In the diagram? also I cant find anywhere the Mounting anti Torque ... part# 1806 75 |
Hi, there are two mountings, one on the engine (No 28) and one on the gearbox (No. 33). There is also the front and rear anti torque links. (No's. 6 & 14 respectively). I'd be very surprised if you can find either of the AT links on sale new but you should be able to find good used ones if needed. |
rozen77
MGmike wrote ... Hi, there are two mountings, one on the engine (No 28) and one on the gearbox (No. 33). There is also the front and rear anti torque links. (No's. 6 & 14 respectively). I'd be very surprised if you can find either of the AT links on sale new but you should be able to find good used ones if needed. Thank you for the explanation... I try to find No. 6 - the front anti torque, I make search the number 1806 75 in eBay, that what I found in the link , its the correct one? - Click Here - |
rozen77 wrote ... I make search the number 1806 75 in eBay, that what I found in the link , its the correct one? - Click Here - Unfortunately none of those are correct for the C6 |
rozen77
MGmike wrote ... Unfortunately none of those are correct for the C6 you have idea where I can search for the anti torque 1806 75 ? |
