NO MAIN BEAM / HIGH BEAM HEADLIGHTS on 2006 C6
citroenroen1
Sun Aug 03 2025, 05:53pm
Member No: #5495
My MAIN bean headlights do not work
(never worked since I got my C6)
(The dipped beams work fine and turn ).
When I select MAIN BEAM , the blue indicator lights up , but no MAIN beam.
Could it be a bad HEADLIGHT BALLAST ?
(the part# on my headlight ballast is 1 307 329 100 but i can't find online)
Please share with me what my problem could be
Sun Aug 03 2025, 08:03pm
Usually this is a broken wire (with a white stripe). Quick fix.
citroenroen1
Tue Aug 05 2025, 02:23pm
Member No: #5495
Tjensen :
please tell me where the broken wire ( with a white stripe) is located and how to gain access to it .
Thank you for your reply
Wed Aug 06 2025, 09:32am
It was done by my garage. Inside the unit (wire broken inside insulation). He showed me the broken wire. I think you will find more information by searching in this system , we are not the only ones with this problem !
jst
Wed Aug 06 2025, 03:31pm
Member No: #2551
Could it be this wire?
citroenroen1
Mon Aug 11 2025, 04:09am
Member No: #5495
was YOUR broken black and white wire on one side responsible for both main beams not working ?
If so, which side has the suspect black and white wire?
Mon Aug 11 2025, 05:56am
One broken wire inside a lamp unit is unlikely (I would never say impossible!) to impact both units.
If both are not working I suspect you either have two faults (one in each unit) or something common to both e.g. the stalk unit, BSI or other common item.
Unfortunately I don't have access to a wiring diagram for the lights and therefore, my approach would be to get a known good light unit to test one side but I guess that's difficult out in LA.
citroenroen1
Tue Aug 12 2025, 01:23pm
Member No: #5495
Tjensen,
Please will you ask your garage which side / where he found that broken wire : (it was good sleuthing by your mechanic to be able to locate that broken wire !)
Tue Aug 12 2025, 07:34pm
My main beam was missing only on one side, sorry for being vague
