2,7 HDI stuck in park
jenskuhn
Wed Apr 23 2025, 12:49pm
Member No: #2756
Hi. My car is stuck in park. I am only able to release it by poking a screwdriver into the right hand side of the gear lever. I have tried testing the function in Lexia (I can hear a small click but I am unsure if it is the right amount of click).
Can the source of the problem be a relay? (And where is the relay located?) Or can it be something with the brake pedal?
Any advice would be appreciated.
Arnonf
Wed Apr 23 2025, 06:55pm
Member No: #4869
This is where the relay sits. When it triggers, it makes a noticeable click and pulls the white plastic lock downwards (this is what you are pressing to manually unlock).
Are you able to move the gear shift out of P when using Lexia to unlock?
If not, it sounds like either the relay or some electrical issue.
jenskuhn
Thu Jun 12 2025, 09:50am
Member No: #2756
Arnonf wrote ...
Thanks for the answer Arnonf. You explanation was helpful. I can hear the clicking so I have ordered a used unit. How much disassembly is required here to remove the unit? Do I need to get under the car (and remove the exhaust system) or is it accessible after removing the console plastics covering around?
TheGerman
Sat Jun 14 2025, 02:28pm
Member No: #3175
Es dürfte auch einfacher mit Austausch des Teils 240778 funktionieren.
Siehe auch hier:
