Directional/non-directional headlamps wiring diagram |
| Author | Post | ||
Arnonf
![]() ![]() Member No: #4869
My C6 Business does not have directional headlamps, but I have a C6 Exclusive parts-car that does have them. Unfortunately, this isn’t a simple headlamp swap, the wiring harness is also different. Could someone please share the wiring harness for both versions so that I could possibly add the missing wires myself? Many thanks |
It might be far more complicated to achieve than you may think, it involves the ECU, steering angle sensors and a lot more than wiring. Have a read through of this download: - Click Here - The old DS was much simpler with rods, wires and springs. |
Arnonf
Much appreciated Dave. I believe that most of the hardware is already installed. The steering angle sensor is standard equipment to allow the ESP system to function. As far as I can tell from the document you shared, the only missing wiring elements are connections 7 & 8 which allow the ECUs of both headlamps to communicate with one another to convey turn angles and fault info. If I recall correctly, the marking LIN indicates a simple wire (ie non-CAN). I’ll see what I can do with this info. |
