Suspension maximum ride height
Tak
Sat Feb 22 2025, 12:36pm
Member No: #4309
Hi, I have recently discovered that my 2009 2.2 200000kms will not rise to the max ride height setting any more. It will move too low, normal and mid-height without a problem but stays at mid-height when max height is selected. No other apparent problems, and suspension oil level is fine. Although it is not affecting using the car, I would like to resolve it before other problems arise. I have had the car for about 5 trouble free years, and I am hoping that it could be something easy to remedy myself.
Could any of you steer me in the right direction if you have encountered this before?
Many thanks
Sun Feb 23 2025, 08:26pm
Is the pump stopping when mid-high is reached ? (=signal problem)
or is it still trying to pump (capacity/pump problem)
(and it might use some time even if it is OK)
Tak
Mon Feb 24 2025, 11:29am
Member No: #4309
Hi and thanks for getting back to me.When in mid high position I select max height position and the rear of car lifts about 1cm.I have left it for about 15mins - engine running - but it fails to move any higher.Then I elect Down - the cars drops a bit and immediately screen displays Mid Height position.Select Down again and car drops to Normal position as usual.
Best regards
