5 broken wires above BSM - amvar rear suspension and steering assist fault
TomekWGM
Wed Feb 12 2025, 08:48pm
Member No: #5768
Hi Friends
Ive got a problem. I found near bsm 5 broken wires. Idk where it was. Maybe someone can help me. Ive got rear amvar suspension fault and sterring assist fault.
Thu Feb 13 2025, 10:47am
Hello TomekWGM,
Can you identify which plug they have broken from?
TomekWGM
Thu Feb 13 2025, 10:49am
Member No: #5768
thats the question - idk where are they from. someone says that it spare wires from BSM to cabin.
Thu Feb 13 2025, 10:50pm
There are a number of wires in the under bonnet electronics box that are not used. They're normally routed under the BSM and just hide out there. I can't say what colours they are but I can check if required?
As to your faults; do you have any error codes?
TomekWGM
Fri Feb 14 2025, 06:04am
Member No: #5768
of course. Here you are:
ESP is not imo connected with this. Ive got rear left sensor fault - Im going to change it tomorrow - but....its snowing.
Fri Feb 14 2025, 01:56pm
Is your car a 2.2 by any chance?
The C1132 relates to the power steering and if it's a solid fault, it will need investigating.
The C1174 & C1176 would suggest you have two faulty rear shock absorbers, a faulty AMVAR ECU or a wiring fault. Checking the wiring is probably the least expensive option to start with.
The U1113 will probably be because of the suspension faults and will likely clear when the others are fixed.
TomekWGM
Fri Feb 14 2025, 01:59pm
Member No: #5768
No, 2.7. - Amvar and steering fault appear after bsm disassembly. Esp fault was before.
Fri Feb 14 2025, 08:38pm
When you say "disassembly" can you elaborate pls, what exactly has been done?
The reason for asking is that the C1132 doesn't apply in a 2.7 and the BSM has no direct connection to the suspension other than possibly the maxi fuses under the BSM.
Have you tried clearing the faults and do they return?
TomekWGM
Sat Feb 15 2025, 06:30am
Member No: #5768
Exactly it was a part for brake booster changing.
Faults come back right away without starting engine.
Yesterday I tried to change abs sensor - but the connector is under fuel tank - wtoday im going to try to do it without removing fuel tank.
Sat Feb 15 2025, 07:44am
TomekWGM wrote ...
can't be done as the cable runs in a groove in the top of the tank. Some have simply cut the cable just before it heads over the tank and joined the new one on.
Sun Feb 16 2025, 10:37am
back to your suspension problem....
There's a Maxi fuse (MF2) under the BSM that feeds the suspension ECU. As you've had all that disconnected, I would start there and check it's in good connection.
You may need to load test it as I have seen a MF appear to work but failed to operate an ABS pump. Best be safe by taking it out, cleaning it and refit or replace.
TomekWGM
Mon Feb 17 2025, 05:01pm
Member No: #5768
Ok, abs sensor changed. Abs/esp working. Tomorrow I will check this connection to maxi fuse under bsm, but if that wasn't work that possible the problem to connect suspension ecu.
TomekWGM
Sun Apr 06 2025, 06:55pm
Member No: #5768
Sorry for silence, but i have a lot of work. Today o checked all maxi fuses - are ok. I dont have any idea were i can find fault....
