C6owners :: Forums :: C6 Support :: 3.0 Petrol and LPG
Engine Ticking
FruitdelaJanais
Wed Jan 08 2025, 04:50pm
Member No: #2345
After warming up (a journey of 30mins), I'm getting an irregular ticking noise, like a switch clicking. Quite audible. It's coming from front right corner of the engine bay (3.0i LPG).
The sound is erratic and does not seem to increase under throttle. After cooling down, 8hrs later, it is absent. It does not react to AC coming on or going off, or to heating ventilation.
Any ideas?
Wed Jan 08 2025, 07:13pm
So a 3.0 Petrol with an LPG conversion?
Not many of those around, so I'm going to give you the best 'guess' at where to look. On the HDi's there is a 'charcoal cannister valve' on the fuel return side and a quick look at the 3.0 Petrol fuel supply shows a 'Fuel Pulsation Buffer' around the same location, part { 6 } on the diagram. Probably behind the offside front wheel arch liner so unless anyone else has a better idea, I would have a look there
M2dis
Sat Jan 11 2025, 03:26pm
Member No: #3475
There are very few active members with petrol engines here probably. I am one of them, but haven't encounter anything like you described.
If you have a Facebook account, I would suggest asking from ES9/L7X (PSA/Renault V6) owners and fans group - Click Here -
Citrofix
Thu Jan 16 2025, 10:39pm
Member No: #1722
Hi
Make a google search on "ticking noise when running on lpg"
