How to enter the C6 car with dead battery?
Krtcho
Sun Nov 10 2024, 10:07am
Member No: #2620
Hi guys,
I have 2.7 HDI exclusive with electric rear seats and while waiting for mechanic to do some serious maintenance which includes removing the engine from the car, the battery went dead. Now I have locked vehicle sitting low on street with no possibility to unlock the doors. Bonnet and hood are closed also.
When I put the key in the drivers door, and try unlock without using remote, nothing happens e.g. window doesn't slide down a bit to enable door opening.
Crashing the window glass is one option, forcing bonnet lock another, but I'd love to have some other option available that doesn't destroy the car.
Please help!
Sun Nov 10 2024, 01:00pm
Hattershaun wrote ...
The design of C6 windows & seals, whereby the window drops down slightly when opening or closing a door, is such that with a flat battery & thus no movement of the window, the seal will flex enough to allow the door to open, BUT, not necessarily enough to close the door.
I have seen a C6 with a broken window where the battery had been disconnected & someone tried to slam the door shut - oops!
The handbook does warn about lowering all the windows before disconnecting the battery. Not that this is much help if you encounter a flat battery & your car is parked in a tight garage space.
If you can open a door then the bonnet, you can attach jump leads or a charger to the engine bay points(C) in the diagram
Sun Nov 10 2024, 02:00pm
The Window won't slide down is the battery is dead but the lock should open and allow you to open the door. As above... do not try and close the door again until power is restored and you can move the window down.
If you door won't open then you need to find a way to reach the bonnet release either through the front bumper with a very long screw driver or removing the undertray and front ducting to allow you to reach up from below. It will be a struggle... good luck
M2dis
Sun Nov 10 2024, 05:42pm
Member No: #3475
Maybe use licence plate light?
Krtcho
Sun Nov 10 2024, 10:02pm
Member No: #2620
Yes, I know that how to connect external battery once the bonnet is open, but getting it open is something I struggle with.
MGmike wrote ...
I'm afraid that forcing window glass to slide down would damage the sliding mechanism.
M2dis wrote ...
That sounds promising!
I was hoping someone had a similar experience and is willing to share the secret of how to open the bonnet.
Sun Nov 10 2024, 11:26pm
I had a broken release cable and did manage to open the bonnet from outside. If I remember correctly, I used a long thing and light to move the mechanism to the left (my left). But you should also (as the say above) be able to open the door without breaking the glass.
M2dis
Sun Nov 10 2024, 11:42pm
Member No: #3475
Tjensen wrote ...
I had a broken release cable and did manage to open the bonnet from outside. If I remember correctly, I used a long thing and light to move the mechanism to the left (my left). But you should also (as the say above) be able to open the door without braking the glass.
You live in Norway, I don't want to believe that you have never opened your drivers door in the winter when the window has frozen solid with the door. It is possible to open the door when the window doesn't drop, I've done this hundreds of times, but I wouldn't dare to close it with window fully up tho.
Mon Nov 11 2024, 11:37am
You could remove a side indicator lamp from the front wing (gently prize with a flat bladed instrument & cloth to protect paint), then apply power to the electrical connector, should then allow the remote control to unlock doors.
