NEW BRAKE PEDAL SWITCH ADJUSTMENT ? (or wrong part ?
citroenroen1
Sat Nov 02 2024, 08:50pm
Member No: #5495
I was sent a NEW brake pedal switch CITR0EN 4534 66 .
THE part# on the SWITCH I received is 995835 T 02 .
The part# on my original OEM switch is 9650688480 .
The NEW brake pedal switch PLUNGER is longer and has less TRAVEL than the OEM switch , so it will not work / fit
Is this the wrong switch that I was sent ?
IS it POSSIBLE TO ADJUST THE PLUNGER LENGTH ?
Sun Nov 03 2024, 09:33am
Have a read of this: - Click Here -
You should be able to adjust the length, but it's a while since I did one.
There will be different manufacturing part numbers cast into different sections of the unit, plus Citroën did change the part numbering system to be consistent with Peugeot when they shared a parts' distribution network
Mon Nov 04 2024, 10:32am
Hello Citroenroen1,
The switch is self adjusting. You can pull it out to maximum length and when you press the brake pedal to the floor and the switch bottoms out, the plunger ratchets down to the correct length. I got a switch only last year to fit to a member's car.
