How to replace 2.7L HDI Diesel leak off pipe replacement : part# 1574E8 |
citroenroen1
![]() ![]() Member No: #5495
I am having difficulty getting to the rearmost pipes of the leak off pipe Citroen Part# 1574E48 (diesel return lines) . I removed the 3 "U" clips and the front 3 leak off pipes from the front 3 fuel injectors without too much difficulty. The rear 3 leak off pipes are buried under wiring and other things and are very difficult to see or access : What parts must be removed to get to these rearmost 3 diesel injector leak off pipes? If a "c" clip holding the leak off pipe is lost, I will be in big trouble! There is a video about replacing these fuel return lines on a Landrover (LR Time) but access to leak lines (fuel return lines) is not obstructed by wiring loom AND the TDV6 diesel engine is out of the vehicle.. |
