| C6owners :: Forums :: C6 Support :: C6 Navigation questions and Map or Software Updates |
Sat Nav direction orientation issue. |
| Author | Post | ||
yorkxx
Hi, I notice somewhat confusingly that my Sat-Nav Direction travels from the top of the screen down rather than the normal Tom-tom style of view to look from the bottom up, which is more sensible viewing direction of travel. Can this direction be changed/orientated on the C6 Nav? Thanks Cheers |
Must be able to as mine works bottom up. Look in the 'Map' menu |
Gobxoy
Select "menu" Select "maps" Select "orientation" Select "north Up (this one?????) Or "vehicle direction" Or "3D" FUNNY I was only playing with this the other day, I tend to use "3D" but noticed when you zoom max out you have to watch the car pointer arrow as it can reorient to north up as it flatens out the veiw. |
yorkxx
Gobxoy wrote ... Select "menu" Select "maps" Select "orientation" Select "north Up (this one?????) Or "vehicle direction" Or "3D" FUNNY I was only playing with this the other day, I tend to use "3D" but noticed when you zoom max out you have to watch the car pointer arrow as it can reorient to north up as it flatens out the veiw. Hi Thanks, I'll give that a try! Cheers |
