C6owners :: Forums :: C6 Support :: C6 Navigation questions and Map or Software Updates
Stuck with RT3 ?
M21
Sat Jun 16 2012, 10:40am
Hi.
I own a 2008 C6 2.2. Hdi Exclusive with manual gearbox.
Navidrive software version is 6.62xxx so guess is the RT3, am I right?
The car was delivered without the Navteq Cd's and I'm finding very hard to download the maps.
I've also read that the RT3 is pretty close to useless in navigation.
The car will be serviced soon in a official dealer. Should I buy the navteq maps or go for the old portable Tom Tom device that I already own?
I know that is possible to update the software version in the dealer, but is it worth it?
Thanks.
Regards.
Sat Jun 16 2012, 10:43am
PM me your Vin and I'll try the car build spec to see what it says.
Sat Jun 16 2012, 02:14pm
Build Spec e mailed to you but it does confirm that it's an RT3 you have fitted I'm afraid.
M21
Sat Jun 16 2012, 03:55pm
C6Dave,
Thank very much for the answer and the e-mail... superb!
So I've to deal with the RT3... so be it. Although it may not be the most advance system in the world is way better that what I was used to (that was a Volvo stereo plus 6 speakers...).
Never the less I'll try to get the maps for the 6.62xx version, meanwhile the Tom Tom will do the job.
Cheers.
Sat Jun 16 2012, 05:08pm
Your welcome
Sun Jun 17 2012, 06:15am
You may want to think about upgrading to RT4/RT5 if you can find a unit on eBay etc.
There is a guide on what to do with useful links over at C4owners: - Click Here -
That's going from RD4 to RT4 but the principles are the same and you have less bit's to find............
Sun Jun 17 2012, 08:56am
Citroën C5 Navidrive RT4
I've copied this from FrenchCarForum.co.uk
I have no connection with this guy nor do I know anything about him, but given what has been discussed.........
I am planning to get an aftermarten dvd for my 08 C5. Wanna sell my navidrive RT4 with a pannel for display. Would it fit other cars without gps units? Is anyone interested in it? Im selling my Navidrive RT4 unit with updated maps Front panel bit and a screen for 350£ono. Anyone interested please contact me on - e mail -
the_unrepentant
Sun Jun 17 2012, 09:36am
I wouldn't say the RT3 is near useless. I actually find it quite good and use it regularly. The lack of postcode is a pain at first but once you get used to it, I find it fairly accurate and the traffic reports and re-direction is also useful. I am currently using the latest maps. If the RT4/5 is so much better, it must be an a amazing system!
RedRay
Sun Jun 17 2012, 09:02pm
Member No: #103
Hi Steve
Give me a call ref the rt4.
Regards Ray
[/quote1339966899]
Gobxoy
Mon Jun 18 2012, 09:40am
RT5 doesn't have post code entry either, (well if it does I ain't found it) only My way which aren't fitted to C6.
I got a feeling that RT3/4 use a fiber optic cable to connect the screen and Rt5 a wire conection or is that RT3 Fiber optic only and RT4/5 cable?
James
Mon Jun 18 2012, 03:08pm
Gobxoy wrote ...
Hardware differences like that are more likely to be 3->4 than 4->5 ,the 4 is a whole new architecture from the 3, the 5 is an updated 4.
Dapprman
Mon Jun 18 2012, 09:52pm
Gobxoy wrote ...
Is it not like the RT4 where there's no obvious entry line, but you put the postcode in the Town/City line (don't remember this being documented in the manual either, I had to be told)
Gobxoy
Tue Jun 19 2012, 07:05am
James You are probably right, that would make more sense.
Dapperman I'll give that a go.
pclark
Tue Jun 19 2012, 07:42am
Member No: #3
It won't take full UK postcodes. For example, If your postcode is YO60 5GH (I made this up - it's not a real postcode AFAIK)You can input YO60 5 which will get you somewhere near. It's not much use in a rural area as my home postcode only differs from where I work by the final 2 letters but it's a different village over 2 miles away.Using the street name may differentiate.
M21
Sun Jun 24 2012, 10:32pm
Anyone knows were I can find Navteq maps compatible with 6.62xx firmware?
That must be one of the rarest downloads out there (everything I found demands 6.63 or higher...).
Regards.
P.S. There's always the option of buying the cds, but I would like to try it first in order to find if it's an alternative to the TomTom device that I already own.
