Idling Vibration through Steering Wheel/Column |
With the car stationary or inching forward in traffic, there is a very noticeable vibration (from the engine?) coming through the steering wheel. If you touch the wheel lightly with one finger, it is almost visible. Anyone have this? Anyone know where to start looking for cause. Pretty sure this has just slowly crept up on me. Regards G |
G, Power steering pump problem perchance?? Regards, Phil C. |
michaelb |
Member No: #14
You've bought a diesel. What did you expect? Sorry, couldn't resist. |
Mike H |
Member No: #53
Well I have this too and through the seat as well. I assume this is normal. Although it is more noticable that in the 407 we have with the same engine /trans. | ||
No its not normal or at least mine never used to do this at all. Something is playing up. Regards G |
Mike H |
Member No: #53
Good to hear as there may be room for improvement. it certainly detracts from the ambience. Seems to me this is an unhappy motor situation. or engine mounts /vibration insulation. Nothing to do with the power steering . recently 2 injectors were replaced ( out of spec) at great cost with no change, ? [%*^#@!] Aus fuel ? |
Mike H wrote ... Good to hear as there may be room for improvement. it certainly detracts from the ambience. Seems to me this is an unhappy motor situation. or engine mounts /vibration insulation. Nothing to do with the power steering . recently 2 injectors were replaced ( out of spec) at great cost with no change, ? [%*^#@!] Aus fuel ? Just wondering G, did you find out in the end what caused the rough idling problem you had? I've noticed a similar vibration now recently as well. |
HiPOL |
Member No: #2699
Guys - check vacuum pressure pipes and swirl actuators. They use same vacuum that is used by front/rear engine holders. When these are broken engine gives more vibrations when idling. | ||
PIT |
Member No: #2671
I have the same problem. A lot of vibrations in the steering wheel when idling. What exactly is the "swirl actuator" so i can check it. |
