Lexia 3 Win 7 - Win 10 Question
Rich
Tue Aug 16 2011, 11:28am
Member No: #542
Hi all
I am about to buy a Lexia 3, but I understand it is not compatible with Windows 7. My question is, on Windows 7, can it be run in XP compatibility mode?
Thanks
Rich
Tue Aug 16 2011, 01:06pm
Yes, according to a member at C4owners
But you need to download the XP compatibility software from Microsoft as far as I'm aware
Rich
Tue Aug 16 2011, 05:49pm
Member No: #542
that's perfect. I run Windows 7 on bootcamp on my Mac so hopefully with that combination it will work! Thanks
David Hallworth
Tue Aug 16 2011, 05:56pm
I use my Lexia 3 via Bootcamp on my Mac also but I bootcamp into XP Pro SP2 not Windows 7 so can't be of much assistance I'm afraid othen then to confirm Bootcamp doesn't affect it.
David.
Wed Jul 03 2019, 08:34am
I’m running Diagbox and Peugeot Planet on a windows 10 netbook without any virtual machine.
keithc
Wed Jul 03 2019, 02:01pm
Member No: #2584
I'm certain I'm running my Lexia on my Windows 10 laptop with no virtual machine. It's almost 2 years since I installed it and don't remember any issues - only it took a long time...
Mon Jul 15 2019, 07:50pm
I can confirm that after having 'online support' to install Diagbox 7.8 on my Win 10 laptop via a 'Virtual Machine', they failed miserably and I sent it all back.
Instead I bought a cheaper Lexia 3 from eBay, downloaded a copy of Diagbox 7.2 iso and ran the instal direct to my Yoga 710 running Win 10 Pro.
It did take a while but it works fine and I deactivated TPMS no problem for a lot less than a dealer would charge.
I understand from Trainman that he has Diagbox 7.2 on his laptop running Win 10 Home so this looks like a good way to go.
Install Guide PDF I used is available to download: - Click Here -
Mon Jul 15 2019, 08:43pm
I do indeed, posted you a pen drive today with it on, oh well........
rwb
Tue Jul 16 2019, 07:57pm
Member No: #1988
I can confirm that Diagbox can be installed on 64-bin win10.
However, my weapon of choice at the moment is 32-bit win7 on an old Dell D610 because I can keep it in the car and because having all the services running on my main machine is annoying.
I've tried vritual machines a few times and either failed or found them to be unusably slow -- not that Diagbox is particularly snappy at the best of times.
Installing is certainly something of a rite of passage.
I find that: install, restart, open Diagbox (it finished installing), restart, then do the same with the next update in the sequence. Diagbox 7.83 was a day's work.
Fri Jul 19 2019, 09:16am
Found out that you can supress that annoying 'update check' screen that keeps appearing with some Diagbox installations.
You can turn off the automatic firmware update:
Find the file C :/ AWRoot / bin / launcher / AP.INI
Scroll down and Change the value of: MAJ_COM = TRUE ---> MAJ_COM = FALSE
Ran a battery test on my car this morning after doing the tweak without it appearing
