Front anti-roll bar bushes and drop links
Biggles1957
Fri Mar 17 2023, 04:04pm
Member No: #3337
Might be a daft question but when changing these should the car be sitting on it's wheels, or lifted up with it's feet dangling? I can't find anything in the technical section...
Thanks!
Bob
speedfix
Sat Mar 18 2023, 12:54pm
Car's suspension set to low, car lifted up with wheels left dangling.
Biggles1957
Sat Mar 18 2023, 01:04pm
Member No: #3337
Many thanks!
Biggles1957
Sat Mar 18 2023, 01:45pm
Member No: #3337
So - daft question now! How the hecky peck do you jack the car up when you've put the suspension in 'low' and loosened the little screw to depressurise it? I do have a low profile jack but not sure if that will fit under! Only time I've lifted the car before was to remove a rear wheel and arch liner to repair the petrol flap lock and I out it in high and just lifted the wheel clear of the ground for that little job.
speedfix
Sat Mar 18 2023, 02:48pm
Ok if your not using a hoist carry out this way.
Set the suspension to high, block car under the four sill marking positions.
Return the suspension settings to low and carry out work as required.
