Coolant/Oil temperature gauge and Tyre pressure page missing |
CC |
Member No: #1528
Hi, when I press the button on the wiper stalk, I can only get instantaneous range information, trip 1 and trip 2 and it goes back to instantaneous, I does not toggle to the page with Coolant/Oil temperature Tyre pressure page. I have tried pressing the DARK button for 12 seconds to reset the unit and it still does not work. Can someone tell me how to sort this out? Thanks! | ||
Chechung, sounds, like its something that needs setting up in the configuration menu, either that or a fault with the comms unit. |
CC, does your car have Navidrive option? If yes, you need to put the display in TRIP mode to get the temperature gauges and tyre pressure monitor. Regards G |
Biggles1957 |
Member No: #3337
I tried that and it still didn't work.... | ||
Reinstall the operating system, then wake up these functions with Lexia/Diagbox. Some C6 functions are not standard and will not show after a disk crash or a standard auto-repair or reinstallation. I had many years of HDD crashes in high altitudes and did this many times. Another tip: Use the operating system disk sold by Citroen (not expensive), not the one that is delivered with the new maps. | ||
