Adjusting the aim of the headlight washers
Stealth
Mon Jan 30 2023, 03:11am
Member No: #986
Hi everyone,
Can anybody provide advice on how you go about adjusting the aim of the headlight washers? Is there a way to extend the washers and have them stop in the open position, like the active rear spoiler?
1 User said Thank You to Stealth for this Post :
 cruiserphil (31 January 2023)
Tue Jan 31 2023, 01:56pm
Hello Stealth,
I'll have a look at one I have spare. I have a feeling you can't. Is there a problem with yours? They can blow out the nozzle pressed into the outlet resulting in you losing the powerful spray action.
 Stealth (07 February 2023)
sotweedfactor
Sat Feb 04 2023, 12:17pm
Member No: #2185
The washers are pushed out under water pressure and return by a spring. No individual electrical control. Not 100% sure, but I think water only gets directed to them when the headlamps are on. You could have the vehicle stationary with lights on and an assistant operating the washer... then grab them, whilst extended, to have a quick inspection. Otherwise it's bumper off to get good access. Like all washer nozzles, they're vulnerable to debris clogging them up.
2 User said Thank You to sotweedfactor for this Post :
 Stealth (07 February 2023) , cruiserphil (13 February 2023)
Stealth
Tue Feb 07 2023, 08:49pm
Member No: #986
cruiserphil wrote ...
Hello Stealth,
Thanks Phil. No problem. They're working powerfully well but the passenger side one sprays a little too high.
Stealth
Tue Feb 07 2023, 08:55pm
Member No: #986
sotweedfactor wrote ...
Thanks @sotweedfactor, I was hoping someone would provide that answer! Excellent. I'll just grab it while it's deployed and see if I can re-aim the sprayer.
